dead battery - best guess?
Installed new battery because the old one was (shot) dead for the same - whatever - reason(?)
Comments? switch stuck in "on" or "activate", ever heard of that?
But made a mistake in my haste to post: #36 is for "passenger power seat" and that breaker was humming/tripping. I had pulled #3 (lumbar support) too. So same question but for passenger power seat: why would that be stuck in one of it's "on" positions. Another guess here: I think it's stuck in "back", not "forward". When the new battery is charged I'll plug in the breaker and try the thing "back" & "forward" to unstick it....
The Seat switches seem to have issues from time to time. I think most are replacing them. I would imagine they can be repaired and Bill Curlee might have some input on that.
It seems to be a common failure and I've heard of quite a few over the years. One of the lower quality parts on the Vette.I wouldn't try to fix it as its an easy replacement. You'll need to pull the seat which takes 5 minutes. The electrical connector under the seat is fiddly to disconnect but apart from that its straight forward.
I'm sure one of the Forum parts vendors will fix you up.
Some pics here:
http://www.vetteessentials.com/instr...r_removal.html
Seat Switch Replacement - Power
Removal Procedure
1. Remove the seat back recliner handle.
1. With a suitable blunt ended tool inserted between the cushion and the handle push the handle retaining spring clip down.
2. Pull the handle from the shaft.
2. Remove the screws attaching the seat side trim panel.
3. Rock the panel side to side working the barrel post clip (1) out of the seat frame.
4. Reposition panel away from the seat.
5. Disconnect the switch harness.
6. Remove the switch.
Installation Procedure
1. Install the switch to the side trim panel.
2. Install a new barrel clip (1) to the trim panel upper barrel post (2).
3. Connect the switch harness.
4. Install the seat side trim panel.
* Push the barrel post with clip through the hole in the seat cover and into the seat frame.
* Install the front and rear trim panel attaching screws.
5. Install the seat back recliner handle.
1. Position the handle retaining spring clip into the lock position.
2. Snap the handle onto the reclining mechanism shaft.
BC
