Head & Cam on my 1999 1st day
I am very interested in this. I have a cam in my car already and looking to put a set of heads and intake on the car this year. Nice work so far. Keep up the good work!
Stuff some clean rags in the lifter areas. I found it very easy for little pieces to drop into the oil gallery for the lifters and think this is a reason so many end up with noisy lifters. Good luck with the remainder of the work.
PS: I found out about the stock castings the hard way as well, my hands were a mess for a couple of weeks.
HELL YEAH!!!! Thats a wicked important note to pay attention to. The gu that did my Heads and Cam re-used the stock bolt. well about 10,000 miles into it she started throwing belts and upon cloaser inspection I saw the pulley was backing out. so another 5 hours and I added a better Pulley with the 28 dollar ARP crank bolt. heated the pulley up to 275 degrees for about 35 to 40 min in the BBQ pulled it off unwrapped the tin foil and placed it on the crank end only about 3 min of tourquing the bolt down got me to 240lbs tq. Made the job very simple.
Ok the last dyno my 99 A4 showed 318 RWHP with these mods
12.8@109 at track with Firestone Wide-Ovals
180 thermo
1.8 crane quick lift gold
B&B shorties
Diablo-Sport Predator
Blackwing + Power Duct
BBK 80mm TB
LS6 Intake manifold
Corsa Catback
Putting In
Replacing 853 heads with CNC 243 by Advanced Induction, Concord, NC
Comp Cams XR265HR-14 Duration 212/218 LS 114 Lift .522.529
(Lift with my 1.8 should be about .532/.539)
New oil pump
LS2 timing chain
LS7 lifters
Expecting ?
What I'm looking for. A very street drivable A4 with more power than a Stock C5 Z06.
180 thermo
B&B shorties
BBK 80mm TB
LS6 Intake manifold
Corsa Catback
Putting In
New oil pump
LS2 timing chain
LS7 lifters
Expecting ?
Summit Underdrive pulley No seal. It is one solid piece. Obviously if you are working with a balancer with a glue joint I would definetly look into the elbow grease method. But if it is the front seal you are talking about then there are no issues and as a matter of fact I am pretty sure that with some of your softest rubber compounds (like your cell phone key pad) that hold normal temperature ratings up to 250 degrees C. That 275 Degrees F will not damage the more rugged EDMP rubber used in automotive grade seals, bushings and gaskets. It worked without fail for me no funny smell after it was in place and no burnt front seal.
The instructions with the summit UD pulley says to heat it before installing.
180 thermo
B&B shorties
BBK 80mm TB
LS6 Intake manifold
Corsa Catback
Putting In
New oil pump
LS2 timing chain
LS7 lifters
Expecting ?
180 thermo
B&B shorties
BBK 80mm TB
LS6 Intake manifold
Corsa Catback
Putting In
New oil pump
LS2 timing chain
LS7 lifters
Expecting ?
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WARNING!!!!!!! Make SURE that each head bolt hole in the block is DRY. If theres any fluid in the hole, when you torque them in place, the fluid will crack the block!!!!!!!!!!!
I used an air chuck with a long aluminum tube that fit down into each hole. You would NOT believe all the crap that comes out.
Use a good light to look into each hole and if you cant see the bottom of the hole, its NOT clean.
The top row of head bolts is a different torque than the rest of them.
BC
BC
MFIC
My plans are for no change on stall converter, so this cam will be as high as I would go.
And no fly cutting of pistons
The 1.8 rocker arms are going to give you more than that for an end result lift. I have a 233-239 .595/.604 lift cam with 1.7 rocker arms. were I to go to the 1.8 I would have a .630-.640 lift. So you are actually looking at about .560-.572 lift (roughly). Honestly I would go with a more agressive cam were I you.
MFIC
I know about the water in the holes
BC
BC
MFIC
MFIC
I made a mistake on the numbers. according to Crane
(Lift with my 1.8 should be about .552/.559)
#34
MFIC
3rd day - little work tonight
Tonight I only removed the the posts and pushrod guides of the 853 heads, cleaned them and left them dry for tommorow with a bit of locktite get installed on the 243's
Look at the intake ports wow !
The exhaust port are very nice too !
853 heads are out of the way now !
#36
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When I installed my Patroit Stage II heads, I de-bured all the sharp edges off of them and removed a lot of the cast flashing. The area around each sparkplug hole was like a razor blade
Now there nice and smooth and easy on the fingers.
#38
Just an FYI: I found that my new heads were even more of a hazard. As I was tightening head bolts I would look down and see new blood... The heads cut so cleanly that I never even felt the skin being cut away!
As a stubborn wrench turner, I pressed forward without gloves and continued to remove more skin...
