I have a '99 coupe with two 6 way power seats. The driver seat moves up and back OK. The lumbar adjust doesn't have any affect. I hear something like a motor when I hit he button but then nothing. The passenger lumbar seems to work OK. I hit the lumbar adjust and it changes. Any ideas what could be wrong?
You can pull the seat cover away with the seat still in the car and take a look
Often the failure is due to the plastic connectors in the air bladder pipes breaking rather than the bladder itself.
And of course fuses. It has been known for the motor to burn out and pop a fuse. Also check that the switch is working prperly. You'd probably need to pull the seat and check with a multi meter to check that out.
