Intake temp sensor wiring help!
Old Jan 25, 2010 | 08:05 PM
1sickz51vette's Avatar
1sickz51vette
Default Intake temp sensor wiring help!
Hey guys my plug on the intake temp sensor broke, so I ordered a new pigtail for it. My question is the new pigtail has a yellow and black wire (I'm assuming yellow will be the positive), but which wire on the stock plug is positive and negative? Does it even matter, I'm sure it does so I'm making sure I don't wire it backwards... Thanks guys!
Old Jan 25, 2010 | 08:12 PM
lucky131969's Avatar
lucky131969
Are you talking about the IAT?
For the factory connector, pin A (purple wire) which is sensor ground from the PCM. Pin B (tan wire) which is 5 volts from the PCM.
Old Jan 25, 2010 | 09:00 PM
lucky131969
Originally Posted by Y2Kvert4me
The purple is ground, the tan wire is the sensor output signal to PCM (not 5v - those are usually gray color wires).
Huh, there I go again, reading the schematics wrong.......
Old Jan 25, 2010 | 09:27 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Meh, that's what I get for going off memory....
The Intake Air Temperature (IAT) sensor contains a semiconductor device which changes the resistance based on the temperature (a thermistor). The IAT sensor is located in the air intake passage of the engine air induction system. The IAT sensor has a signal circuit and a ground circuit. The PCM applies 5.0 volts on the signal circuit to the sensor. The PCM monitors the changes in this voltage caused by changes in the resistance of the sensor in order to determine intake air temperature.
When the intake air is cold, the sensor (thermistor) resistance is high. The PCMs signal voltage is only pulled down a small amount through the sensor to a ground. Therefore, the PCM senses a high signal voltage (low temperature). When the intake air is warm, the sensor resistance is low. The signal voltage is pulled down a greater amount. Therefore, the PCM senses a low signal voltage (high temperature).
When the PCM senses a signal voltage lower than the normal operating range of the sensor, this DTC will set.
But regardless, the sensor is still not polarity sensitive. current can flow in either direction through it, so it does not matter which wire is which at the sensor.
Old Jan 25, 2010 | 09:30 PM
1sickz51vette
oh okay great thats all i need to know, and yes I was talkin about the IAT sensor on the air bridge. Can the sensor itself go bad, if its not the clip?
Old Jan 25, 2010 | 09:32 PM
lucky131969
Yes, but it's not a "common" failure.
Old Jan 26, 2010 | 02:55 AM
1sickz51vette
okay thanks for all the info, I am running a twin flow polished intake... The wires were fragile on mine seeings its a 97' and i ripped them out the clip by accident. Did the best I could to try and repair the clip, but I'm guessing it wasn't good enough.
To Intake temp sensor wiring help!
