Reverse lock out not working.
Old Jan 29, 2010 | 12:43 PM
INTRUBL's Avatar
INTRUBL
Default Reverse lock out not working.
Be real careful finding 5th. How much of a job it it to get it fixed? Thanks.
Old Jan 29, 2010 | 04:40 PM
garllo's Avatar
garllo
Hi there,
First, be absolutly sure that the problem is with the reverse lockout. I had a similar problem when I first got my C5. Shifting into 5th would cause a grind. First I thought that it was just me then I thought that I was hitting reverse and after some research ,I ended up doing a shifter alignment-End of problem! Hope that this helps out..
http://rpmtransmissions.com/files/c5...adjustment.pdf
Old Feb 7, 2010 | 11:56 AM
jrC599's Avatar
jrC599
I agree be careful. I think mine failed last nite and now I don't have a reverse gear.
I say this cause I was trying to find 5th going on the freeway it grinded so I didn't force it and eventully found it. Well, when I tried to leave the place I was at it couldn't reverse! The back up lights go on but all it does it grind and not move at all.
I'm not sure if I can replace one gear or do I need a whole new trans. I hope not on a whole trans.
To Reverse lock out not working.
