Zip ties, medium duty wire, grunting and pushing - - - You guys are barbaric. You just put the Easy Shock on them, snug it up, pull the bolts, compress the Easy Shock and lift the old one out. Reverse the process with the new one. Couldn't be any easier. Takes a half hour for four shocks and you can do it with a cup of coffee in your other hand.
Just yanking your chains guys, I made it myself. BUT, it does work like a charm on C5, C6, Bilstein and probably other shocks both front and rear.
You dont want to rent that tool out ...do you?...LOL
More info on thickness....hole size...etc....thanks
Had a couple of PMs about ride height change, so I'll just post it here.
From what I have read, it will settle back to it's original height after a few days, but for he record, I made very precise measurements before and after the install, and the changes were;
Rear +3/4"
Front + 7/8"
This was much less than I expected, and I have no reason to think that the car will settle back to original height after a couple of drives.
Rear +3/4"
Front + 7/8"
Geez I sure hope so. I was thinking about getting them but the stock C5ride height is already 4x4 looking above the wheels. Another 3/4" would make it look even worse. Please let us know.
I did not measure the before-after ride height .. but visually I'd say its a good 1/2" higher - put them on sat. and I think it has settled a bit but not back to the original height - my front is adjusted all the way down on the stock bolts (no cut bushings) so I hope it drops back more. Will report back. As far as the ride, I definitely like the feel of the shocks - yes firmer but not at all harsh - and No float at all ... just right combined with the c6-Z51 sways.
Seems everyone is using the C6 Z06 shocks on their C5's... I though I saw a few posts/threads on using the C6 Z51 shocks, did a search, but couldn't find anything... I just picked up a set of new take off C6 Z51 shocks and swaybars for my C5... haven't installed them yet, I hope the improvement is as good as with the Z06 pieces...the swaybars sure are a lot bigger than stock C5...
Didn't someone say that using the old bushings from the C5 shocks would maintain the stock ride height?
Hello all. New to post here. I just bought a '97 from a forum member. I would like to lower the car some more and was wondering if the C6 Zo6 shocks are shorter than the C5 Z51 shocks. The car is now lowered on stock bolts with 18/19 wheels. If I remove the front bolts, what are my shock options? Thank you!
So should I look for Bilstein Sports for my year/make/model? It seems like if I ordered Bilstein Sports for my car they would be the same length as stock shocks. Does anyone have part numbers for the shorter Bilstein Sports?
