clutch
Old Feb 10, 2010 | 10:48 PM
davezo6's Avatar
davezo6
6th Gear
Default clutch
ok gang thanks for all the help and advice on my clutch having a hard time going into reverse on my 2002 zo6.now my next question is Does $1600.00 bucks sound about the right price to replace this clutch.my corvette mechanic said its a major job that the rear and tranny have to come out and pretty much you are looking at a shell of a car.
Old Feb 10, 2010 | 10:56 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Sounds about right if it includes the cost of new clutch, slave, master, pilot bearing and throw-out bearing.
Old Feb 10, 2010 | 11:44 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Yikes I hope that includes parts. Yes it is a big job. My advice is go with after market and avoid factory parts except for the slave cylinder and pilot bearing.
Old Feb 11, 2010 | 12:21 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
Yes the trans,torque tube, differential, rear subframe, exhaust(Also the headers if you have them) all have to come out. The price depends on what parts he is going to use.
Old Feb 11, 2010 | 12:27 PM
Han Solo's Avatar
Han Solo
Yeah by all means get a factory pilot bearing so it can disintegrate like mine did.
Screw that, go to NAPA and get a bronze oilight bushing to replace it with.
Old Feb 11, 2010 | 01:43 PM
Tech's Avatar
Tech
$1600 seems reasonable depending on what parts they are including.
FWIW, I prefer the GM roller bearing.
Old Feb 11, 2010 | 10:39 PM
Carcass's Avatar
Carcass
I messed up an oem pilot bearing during the drivetrain reinstall,so I got to do it twice.
I went with a Kevlar Composite pilot bushing on the second go-round,and it's got about 1200 miles on it so far,and it's working sweet.
About $50.00 from Jegs,but so far,definitely worth it...
Also good if the disintegrated roller bearing chewed up the propshaft,like mine did
Old Feb 11, 2010 | 11:54 PM
Han Solo's Avatar
Han Solo
The one I pictured above came out of my car with 44,000 miles on it. I'm pretty sure it was dead long before I pulled it.
Through my career as an auto tech I've done 100s of clutch jobs on all kinds of cars. I've never pulled a pilot bearing that wasn't at least noisey. I've seen many of them weld themselves to the input shaft on Volvo's (major pain to pull the tranny with a bearing welded to the input). I have never seen a pilot bushing beat out on anything. I always replaced them as you should but never pulled one that looked much different than the new one.
Old Feb 12, 2010 | 11:04 AM
Tech's Avatar
Tech
Interesting. I don't have 100s of clutch installs under my belt. However, on the 10-12 that I've done on various GM vehicles, I've always used the bearing and never had a failure. My Firehawk came from the factory with a bushing, but I replaced it with a roller bearing. It seems like a bushing would be cheaper to make than a bearing.
Old Feb 12, 2010 | 01:05 PM
Eric D's Avatar
Eric D
Is that greese around the bolt heads?
Old Feb 12, 2010 | 05:38 PM
0HorsePowerAddicts
Former Vendor
Looks like he used blue locktite on the bolts.
Old Feb 13, 2010 | 03:12 PM
cantrelmitl's Avatar
cantrelmitl
St. Jude Donor '10
I would upgrade your flywheel to lightweight or aluminum while you are in there. I went with a fidanza and man it made a huge difference. My 400 plus RWHP engine felt like I gained 30 to 40 RWHP. If you're in there, all you will paying for is for the flywheel itself. I even changed out my torque tube when I did mine . . . it's $$$ saved on down the road. As everyone stated, it is a huge project and depends on the clutch you put in. SPEC makes some nice setups w/o killing your budget. I've had two different SPECs, went from a SPEC II to SPEC III plus.
Mike C sends
Old Feb 14, 2010 | 01:24 AM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
Hey I just noticed your main complaint was your tranny is hard to get into reverse. Are you sure you need a new clutch? Could be simple as wiring or the connector for the reverse lock out solenoid, or the solenoid itself. Could also be the alignment of your shifter. A simple fluid change has helped some people. A toasted clutch wouldn't usually make it hard to get into reverse.
To clutch
