Cone Filter Cleaning
Old Feb 13, 2010 | 01:30 PM
gekay1's Avatar
gekay1
5th Gear
Default Cone Filter Cleaning
I have the Twin Flow cone filter intake, I can not find the cleaning instructions. I know it does not use the K&N Oil, however, any suggestions on cleaning the filters?
Old Feb 13, 2010 | 02:02 PM
hotwheels57's Avatar
hotwheels57
Not knowing what type of filters yours are...
You can clean with diluted SIMPLE GREEN, spraying onto the outside pleats and allowing it to do its thing for a few minutes, then rinse under running water. Flush the contaminants from the inside to the outside.
This is an acceptable procedure with a K&N, S&B or Blackwing, anyway.
Allow the filters to air dry only. Do not use compressed air.
Old Feb 13, 2010 | 02:03 PM
bobby777's Avatar
bobby777
Dairy Queen has a special on a double dip cone-
Old Feb 13, 2010 | 02:23 PM
Dave68's Avatar
Dave68
Default Voila!
I think this is what you are looking for:
http://volant.com/cleaningInstructions.pdf
And here's the cleaning kit:
http://volant.com/filter_kit.asp
Old Feb 13, 2010 | 10:02 PM
jrose7004's Avatar
jrose7004
Clean with Simple Green, water and a soft brush. Recharge with a mixture of mineral oil mixed with alcohol in a spray botter. Spray it on, the alcohol will evaporate leaving the oil.
To Cone Filter Cleaning
