Best catch can?
Old Feb 18, 2010 | 06:08 PM
95wht6spd's Avatar
95wht6spd
Default Best catch can?
I want to get a catch can for my Procharged Z.
Who makes the best one, Rev-Extreem, CCA, Elite, etc?
Why is it better?
Is one easier to use/empty than the other?
Old Feb 18, 2010 | 06:19 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I have the Elite one. Very well made, the whole thing is machined billit.
The entire bottom half unscrews in about 4 seconds and you can pour the oil into any container you want. Screw it back on the body in 6 seconds.
The others with little drains on the bottom don't seem as clean or smart.
Old Feb 18, 2010 | 06:39 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
The only problem you'll have with the Elite unit is the machined bracket. It bolts to the passenger cylinder head with supplied stainless hardware. The Procharger is in the way.
Call Elite and see if they have an alternate bracket. I'm sure they can make one for you if nothing is on the shelf...
Old Feb 18, 2010 | 07:56 PM
95wht6spd's Avatar
95wht6spd
Good point, I really want something easy and off the shelf in a complete kit, and a good value. I know the CCA is a complete kit and less $, not sure about the mounting w the SC.
Old Feb 18, 2010 | 08:42 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Best catch can on the market that really works
Saikou Michi
Old Feb 18, 2010 | 08:56 PM
7LitreC5's Avatar
7LitreC5
I have been doing research on catch cans and the Saikou Michi seems to be highly rated. I ordered the dual can last weekend and should have it soon.
Saikou Michi
Old Feb 18, 2010 | 09:19 PM
Dennis Wilson's Avatar
Dennis Wilson
I have a CCA & it looks & works good.
Old Feb 18, 2010 | 09:20 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
^ Who sells that dual can?
If it's really the best.... there may be a polished Elite can up for sale soon..
Old Feb 18, 2010 | 09:22 PM
7LitreC5's Avatar
7LitreC5
They are only sold direct as far as I know. Just google the name and you'll find the web site.
Old Feb 18, 2010 | 09:40 PM
printmanjackson
there are several post on ls1tech about this catch can
Old Feb 18, 2010 | 09:42 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
^ It's really custom. The website said you have to discuss your vehicle before he makes it. It also seems like he doesn't like polished metal very much.
Old Feb 18, 2010 | 11:04 PM
95wht6spd's Avatar
95wht6spd
Why are these better?
Old Feb 19, 2010 | 12:34 AM
printmanjackson
contact Mr. SAikou
Old Feb 19, 2010 | 06:00 AM
dieseldave56's Avatar
dieseldave56
Default affective installation
Lest we forget , installation counts for a fair % of the ( any) catch cans affectiveness. Mount as far away from the heat source(s) as condensation plays its role( important to reduce gasses and container temperature) . Mount can below the PCV outlet and inlet points to utilize gravity.
When choosing an oil catch can consider the ID hose size ( larger is better), the condensation /baffle/ separator material and flow design. All are not equal. Some cans have no filter or baffles at all.
Interesting to note the progression of the OEM LSx PCV system(s) designs with the LS1 valve cover baffle to the under valley cover LS6 baffle to the LS2 dual ( inlet and outlet oil baffle /separators. An aftermarket oil catch can will enhance even the least effective of these (LS1).
The are some OEM 'oil catch cans' ( generic terminology)that return filter/ separate fouled crankcase vapor and return captured bulk oil to the lube oil crankcase or resevoir. This can be argued pro and con.
An affective design deals with water moisture as well as oil fouled crankcase vapors and does not reduce air flow thru the cankcase closed loop PCV system. Inovations such as utilizing a coalescing filter in place of the ordinary particulate mass filter . Or join forces and incorperate both particulate and coalescing filters in one CCA/Mike Norris catch can. Also use 1/2 OD spiral bristles brass pipe cleaner ( cut to 4" lenght ) that is installed in the 1/2 ID return hose.
Old Feb 19, 2010 | 08:47 AM
cdkcorvette7's Avatar
cdkcorvette7
Saikou Michi
Old Feb 19, 2010 | 09:56 AM
Dave68's Avatar
Dave68
I looked at quite a few designs, but before I elaborate here, I can direct you to most of my thoughts and criticisms, here.
http://www.conceptualpolymer.com/PCV...oval%20102.pdf
Most, if not all of of the cans mentioned in this thread are included.
Old Feb 19, 2010 | 12:46 PM
Brandon619's Avatar
Brandon619
ARE Aluminum catch can is by far is the best catch can I've used.
http://www.drysump.com/catchcan.htm
To Best catch can?
Old Feb 19, 2010 | 03:13 PM
Dave68's Avatar
Dave68
I would be a bit leary about welded-shut housings like that, unless the units are considered to be throw-away if a buildup of contamination renders it useless.
Old Feb 19, 2010 | 03:20 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Mike Norris can and he installed it so I know it's in the right position.
It's to bad he moved to Indy.
Old Feb 19, 2010 | 05:08 PM
95wht6spd's Avatar
95wht6spd
I agree and like your set up, and good info. on the PDF. I would like to be able to see how much oil is collected.
