Best catch can?
Old Feb 19, 2010 | 05:10 PM
95wht6spd's Avatar
95wht6spd
I wish everyone would state WHY they think a certain make is better than the other, and not just "this is the best one" so we can discuss and compare. Most people are going to say the one they purchased is best.
Old Feb 19, 2010 | 09:13 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Originally Posted by Brandon619
ARE Aluminum catch can is by far is the best catch can I've used.
http://www.drysump.com/catchcan.htm
I've seen that one on drysump systems before. I don't know how it would work on a PVC system.
Old Feb 19, 2010 | 09:22 PM
Mike@NorrisMotorsports's Avatar
0Mike@NorrisMotorsports
Former Vendor
St. Jude Donor '11
Of course mine is the best It is sold by CCA and a few other dealers. With a few thousand sold they speak for themselves.
Most of the better catch cans do well and I am personally a big fan of billet over the sheet aluminum models. I tried to keep my cans compact with a reasonable capacity as well being very affordable. I also take a lot of pride that my units are made completely here is the USA and not sure everyone else can say that. If they can that is great.
There is also a mention of a dual can setup. Folks may be interested in these couple pics of a bracket for that.
Thanks.
Mike Norris
Old Feb 19, 2010 | 09:33 PM
95wht6spd's Avatar
95wht6spd
Mike, what would you recommend for an LS6 w a Procharger? Wouldn't it be better to mount further away from engine than in pic?
Old Feb 19, 2010 | 10:24 PM
trackboss's Avatar
trackboss
All the catch cans are pretty similar. I do like the saiku michi ones myself, but recently I built my own in order to route it correctly. No one offers a can like I want so I built my own. What I did was vent both the valley cover and the pass. valve cover to a single can. Then I vented the can to the non-vacuum side of the throttle body and plugged the fitting on the intake. The reason being to not help the motor suck in any oil. The way I did it the crankcase vents as needed. The other option was to plug both the fitting I did and the t-body and weld on a tube at the top with a filter attached and vent to the atmosphere. It is never a good idea to vent to the atmosphere and still attach a hose to the t-body nipple or the manifold nipple (worse) because unmetered air will be drawn into the motor causing a lean condition (usually a minor one). My can has a baffle I welded inside and I welded on all an male fittings for plumbing and drain. I only had some scrap super thin aluminum laying around so it was a challenge to weld and doesn't look all that great, but it does the job well.
Old Feb 20, 2010 | 01:49 AM
Dave68's Avatar
Dave68
Originally Posted by 95wht6spd
I agree and like your set up, and good info. on the PDF. I would like to be able to see how much oil is collected.
Thanks; once you get used to 100% visibility (using glass), you become a bit spoiled. Aluminum may be a better choice in hot areas and in certain climates but I would recommend that a catch can not be bolted directly to a hot engine component. The cooler the "can", the greater the oil entrapment. Of course, the heart of a catch can is the filter and based upon what I've seen, if you use a catch can that contains wire-type media, you might want to install a screen to prevent loose fibers from being pulled away from the "bundle".
Old Feb 20, 2010 | 12:31 PM
Former Vendor
St. Jude Donor '11
I have seen them mounted onto the actual Procharger bracket and others have moved to the area by the battery as well as down by the AC condensor. From what we have tested it does not matter how close or far away from the engine the unit is. You just have to be sure that with a location requiring a lot of hose that there are no "dips" in the hose that can collect oil and possibly plug off the system.
Mike Norris
Old Feb 20, 2010 | 08:20 PM
Dave68's Avatar
Dave68
Unless one has a particle counter, and sophisticated vacuum/flow/heating equipment configured to SAE specifications (only one company in the US has this capability), there is no reliable way to measure the differences while simulating real-world conditions.
Talk to any person well-versed in pneumatic filters (designed to trap compressor oil blowby) and he or she will verify that the filter should not be close to the heat source.
A catch can that is cooler than the blowby gas contacting it will allow moisture in
the gas to condense on the inner surfaces of the catch can. While moisture in of
itself is not very harmful, it can react with other residual elements to form acid.
Therefore, trapping both oil and water is beneficial to engine longevity.
Old Feb 24, 2010 | 06:40 PM
95wht6spd's Avatar
95wht6spd
Dave68-
Can you list parts needed for your set up?
Old Feb 24, 2010 | 06:45 PM
Dave68's Avatar
Dave68
I added approx. 6 ft of 3/8-inch ID fuel line hose, 4 wormgear clamps and a couple of 8-32 screws to bolt the bracket to the side frame.
dave
Old Feb 25, 2010 | 10:28 PM
Jorge's Avatar
Jorge
Look at Dave's catch can carefully some good features.
I have been using his can for about two years now no more oil in my engine
easy to see thru glass.
Old Feb 25, 2010 | 11:08 PM
Brandon619's Avatar
Brandon619
Yeah it maybe overkill for my system but ARE makes some great products.
Old Mar 15, 2010 | 10:43 PM
  #33
fatbillybob's Avatar
fatbillybob
Trackboss...which side do you consider the non-suction side of the throttle body? Got a picture?
Also, do you guys have an explanation why my 2004 C5Z racecar can use no catchcan and use no oil on track at all in a weekend with no visible oil in the intake and my 4 friends running the same car are blowing all kinds of oil and having to drain catchcans daily? But they run older 2001-2003 Z's.
Old Mar 16, 2010 | 12:41 AM
  #34
trackboss's Avatar
trackboss
The barb on the t-body is non-vacuum. The barb on the manifold is vacuum.
My '99 uses no oil and next to nothing in the catch can even after a day at the track. This was even before the current can. What is weird is I'm told that occasionally there is some smoke out the exhaust under deceleration. Also, I find the intake manifold gets pretty oily. Not sure how it gets there and somehow bypasses the can(s). The current catch can up above I have yet to test on track, but will in the next few weeks. I do know that on the dyno, the old setup ran just a tad leaner than the current one.
Old Mar 16, 2010 | 01:31 AM
  #35
fatbillybob
My guess is that the oil is getting there as a vapor. Then the vapor falls out of the gas state to a liquid. All the extra surface area in there makes a difference and it is relatively cool. If you could cool a catchcan say run the car for a couple laps with some dry ice around the can I wonder if it would be full of oil.
My thinking is you want blowby out but a crackcase vacuum if you can. You don't want the pumping of air in and out of the crankcase. So I like your idea of valve cover and valley into one can. I was thinking that too as a possibility. But what about venting the line to the T body to the atmosphere instead via a breather to guarantee no oil in the intake BUT put a check valve in the line before the breather so that air can come out but nothing goes back in? I'm racing of course no interest in being smog legal.
Old Mar 16, 2010 | 10:25 AM
  #36
Dave68's Avatar
Dave68
That's easily explainable: First, the diameter of the filter media strands you are most likely using are large enough so that oil droplets smaller than approx. 5 microns will easily squirm past the media. Second, it looks like your can bracket is bolted directly to the engine. Since blowby gasses can exceed 160F, little condensation of the oil droplets is happening.
As I mentioned, previously, the maintenancefree-for-a-year goal of most catch can designs require that the filter not get clogged too easily. This is why I advocate a mounting location that aids in the oil removal process.
Old Mar 16, 2010 | 10:26 AM
  #37
Dave68's Avatar
Dave68
I use the same one. I'm glad it's working out for you, Jorge.
Dave
To Best catch can?
Old Mar 16, 2010 | 05:25 PM
  #38
trackboss's Avatar
trackboss
fatbillybob, in your case I would recommend you install a catch can the way I have on every race car I've ever built or worked on. Vent all lines to one can with a filter on top so it goes to the atmosphere. Plug all barb fittings on the motor. This is by far the best way to vent a motor. On street cars it is not all that practical. Especially since smog is a concern. In addition, on the race cars I've always welded -12 fitting on the valve covers (wet sump motors only). On the corvette, that is good as well, but the valley is a good place to allow breathing as well. You could build a catch can with three inlets to vent from all locations.
Dave68, I built my own catch can above. I welded a baffle in it, but there is no filter. In any case, even with some oil in the intake (not yet with this can), the car runs well. I placed the drain on my current can so it is very easily drained if it ever needs.
Old Mar 18, 2010 | 12:38 PM
  #39
fatbillybob
So what do you guys think of check valves in the bleeder lines? crankcase air ok to the atmosphere or T-body but no air flow back to the crankcase. I think check valves make sense. Maybe ones that are used for fuel tank vent valves should be cheap and available.
Old Mar 18, 2010 | 03:17 PM
  #40
Dave68's Avatar
Dave68
The PCV valve is a check valve.
