AC question
Old Feb 24, 2010 | 08:38 PM
flcpl4fn's Avatar
flcpl4fn
Default AC question
I'm having problem with my AC. Yesterday I went out for lunch. The AC worked good. As I was getting back, the AC light went off. I pushed the button several times and it would flash 3 times then go out again. After work I ran the codes and there was no codes for the AC system.
This morning before I left for work, I checked the belts and they were good. So I stated the car and the AC worked and worked all the way to work. When I got off of work, I started the car and the AC didn't work again. The light did the same thing.
Because it works sometimes, I'm sure it isn't a major AC part or a fuse. But it seems like a relay. So here's my question. Where are the relays for the AC?
Old Feb 24, 2010 | 08:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Read the owners manual. Make sure that your not in a MODE that will not allow the AC to run. What was the outside temp?
Check the DIC for DTCs If there is something wrong, it will show up there as a DTC error code and that will tell us whats wrong.
READING YOUR Engine Diagnostic Codes (DTCs)
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open etc…)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes)
If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, C or ;H. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present;
press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET
To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
Here is very good site of DTC definitions:
http://www.gearchatter.com
Make sure to include the H or C suffix!!
Old Feb 24, 2010 | 09:00 PM
flcpl4fn's Avatar
flcpl4fn
Thanks for answering Bill. I know you know your stuff about electrical problems on the C5's. I did check and I'm in the right mode. I also checked the DIC for DTC for codes and it said "no code". I did that yesterday and tonight. That what makes me think it could be a relay.
Old Feb 24, 2010 | 09:28 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When the light FLASHES, it indicates an illogical request OR something is wrong with the system and it cant preform your request or is unable to preform your request.
If you dont have a DTC, start with the basics. Check the AC drive belt and the AC system fuses.
Instrument Panel Fuse Center
HVACCON Fuse#27
HVAC Fuse#18
Fuse #51
Under Hood Fuse Center
PCM fuse#16
Ignition realy#42
Old Feb 25, 2010 | 06:11 PM
Disarray_kid's Avatar
Disarray_kid
To AC question
