OBD 2 Readiness Monitors.
Old Feb 26, 2010 | 04:57 PM
540 vette's Avatar
540 vette
Default OBD 2 Readiness Monitors.
Do all the monitors have to be set as ready to pass emissions inspection. I live in NY and I know they use the federal guidelines.
Old Feb 26, 2010 | 06:01 PM
trussme's Avatar
trussme
you can miss 2 ready-ness codes in N.C. & pass....time to move sowth..
Old Feb 26, 2010 | 07:43 PM
Wt99C5's Avatar
Wt99C5
Depends on year and state, my 99 was able to pass with 2 not ready conditions. Here's info on my adventure. It's pretty old but I believe it's still valid information.
http://forums.corvetteforum.com/c5-t...t-failure.html
Old Feb 26, 2010 | 09:22 PM
AntonioZ06's Avatar
AntonioZ06
NJ has pretty similar laws as far as inspections go. I failed readiness with 2 sensors. I believe in NJ anything reading "not ready" will fail. To let you know, I have a vararam which occasionally throws a maf/lean code. I reset it usually as I comes up. What I didn't think about, was deleting the OBD code also resets the sensors. 2 days later, I went for inspection, not realizing and failed. Drove around for a few days and went back and passed.
Old Feb 27, 2010 | 02:24 AM
striper's Avatar
striper
In NJ the two rear sensors can be tuned out and you will still pass the state inspection with no problem. Call Doug at East Coast Supercharging in Cream Ridge, NJ for more info. The same probably will work on NY cars. Besides when he does your car will run better.
BTW, interesting thing this week. I was getting codes on my S-10 pickup. It turned out I had a faulty O2 sensor. It just so happened the faulty sensor is the same as the two no longer needed in my Vette exhaust. Cheap fix, works perfectly. Glad the General was thinking ahead.
Old Feb 27, 2010 | 03:40 AM
540 vette's Avatar
540 vette
I did some reading and most states follow the Federal EPA standards. Any car 1996 to 2000 can have 2 monitors not ready and 2000 and above 1 monitor. So if you have a check engine light and and reset it and can get it there before it goes on and you only have 2 monitors not ready you are O.K..
Old Feb 27, 2010 | 03:47 AM
LoneStarFRC's Avatar
LoneStarFRC
Depending on the year model vehicle, OBD II vehicles can miss either 1 or 2 and still pass in Texas. At least in the most restrictive counties in the state.
Old Feb 27, 2010 | 08:02 AM
dougbfresh's Avatar
dougbfresh
You local DMV has a website-I'm sure it's there somewhere.
Old Feb 27, 2010 | 08:11 AM
SUPERCRUZ's Avatar
SUPERCRUZ
Do NOT do this. Every time you clear codes you reset all your monitors to a Not Ready state. Most will go back to a Ready state only after you complete a certain number of drive cycles. This was done for reason so you cannot just clear codes and go to the inspection station and expect to pass. Pull the codes and find out which system is causing the check engine light and address the issue. You can have 1 system Not Ready as long as the check engine light is not lite and still pass. You do not say if your car is modified or not. If so, there are ways to tune around the issue in some circumstances, but if your car is stock, get the issue causing the MIL fixed. Good luck with it.
Old Feb 27, 2010 | 10:32 AM
540 vette's Avatar
540 vette
Who said anything about reseting codes. I was just discussing how you can pass with a couple of monitors not being ready even though you may have a problem and the chech engine light is not on.
I have a friend with a Ford Taurus and the car needs cats. He dosen't want to put in $700 for cats so he resets the computor and goes through the drive cycle until all the monitors are set except the cat one. He goes in and it passes.
Old Feb 27, 2010 | 10:40 AM
LoneStarFRC
I have a speed density tune and a MAF code since my MAF is of course not functioning. Since this is my only code and everything else was OK, my tuner turned off the check engine light and I was good to go on my inspection. This is an example of what you speak.
To OBD 2 Readiness Monitors.
