cats vs. no cats
Old Feb 27, 2010 | 09:58 PM
warriorp's Avatar
warriorp
Default cats vs. no cats
im going to pick up a set of lg streets hopefully sometime this week and im not sure if i should get cats. has anyone done a back to back comparison with and without? off road in our area is not a big deal just dont want it to be obnoxiously loud...ill be keeping the stock ti cat back and installing a 228/232 112 lsa cam
thanks for the input
Old Feb 27, 2010 | 11:07 PM
motogib1's Avatar
motogib1
I had the same question when I had my headers installed. Get the cats. Cars without cats tend to be stinky and there is virtually no extra power to be gained. I had random tech cats installed and I am glad that I did.
Old Feb 27, 2010 | 11:30 PM
tlc0706's Avatar
tlc0706
Old Feb 27, 2010 | 11:32 PM
Mark C5's Avatar
Mark C5
Unless you have rear mounted turbos I can see no downside to having cats and plenty of upside.
Old Feb 27, 2010 | 11:52 PM
black98c5's Avatar
black98c5
I've tried both with and without cats. Without the cats I noticed it being a lot louder and you'll **** people off behind you with the smell..especially if you have a big cam . I didn't dyno it back to back or anything, but I'd say you gain a few hp...probably not worth it unless you're after every last HP. I'd just go with the Hi-Flow cats.
Old Feb 28, 2010 | 12:56 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I have hi flow cats and they smell. Maybe not as bad as no cats, but they stink.
Old Feb 28, 2010 | 01:51 AM
Z0SEX's Avatar
Z0SEX
great question, I have been looking for some incite on this topic as well.
My issue is that the LGs with cats is around $300-400 more...
Old Feb 28, 2010 | 12:59 PM
Dave concrete's Avatar
Dave concrete
You don't get the fart smell but general gas fume smell is bad. Sometimes I think I'm starting a 70's car. Really should have them you will never notice a power loss with the hi-flows and if you ever have a problem with getting inspections at least they will be present for the visual.
Old Feb 28, 2010 | 02:45 PM
tb30570's Avatar
tb30570
My Ion Redline no longer has a cat. It smelled a lot at first, but the smell was less and less over time. After a few months, it didn't smell anymore.
When I had the CPU tuned, they turned off the down-stream O2 sensor so the check engine light wouldn't turn on. I've heard you can modify a spark-plug defouler and put it inline with the down-stream O2 sensor to reduce exposer and trick the CPU into thinking there is a cat.
Unless you can get high-flow cats for free, I would leave them off if I were you.
Old Feb 28, 2010 | 03:06 PM
CharlieB1979's Avatar
CharlieB1979
pass inspection vs no pass inspection
Old Feb 28, 2010 | 03:19 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Pass either way quite easily.
Not sure why a TX resident would be concerned about NY inspection procedures though.
Old Feb 28, 2010 | 03:25 PM
tb30570's Avatar
tb30570
inspection? what inspection?
Old Feb 28, 2010 | 09:40 PM
warriorp's Avatar
warriorp
thanks for the info...im tight and dont like to let go of the $$$ unless its worth it...guess ill be counting a few more pennies
Old Feb 28, 2010 | 09:57 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I vote no cats .... I'm a dog person too
Old Mar 1, 2010 | 10:34 AM
TurboBerserker's Avatar
TurboBerserker
BTW, I have no cats and passed inspection with no issues in NY.
Old Mar 5, 2010 | 06:53 PM
kh400's Avatar
kh400
There's a guy on this forum advertising OBX stainless system with cats for $899 and they look really good. FYI, good luck!!!
Old Mar 5, 2010 | 09:04 PM
seering's Avatar
seering
cats also make a noise difference...
NO cats on mine was really REALLY nice at idle ...
stomp the pedal .. and i felt like my ears would ring for 20 minutes
no cats gave mine a really harsh metal ring to it in the range of 2500-3100 RPM .. right where i cruise
had to put them back on ...
I vote Cats. (and a dog .. and some fish)
To cats vs. no cats
Old Mar 5, 2010 | 10:19 PM
lionelhutz's Avatar
lionelhutz
Cats should be a little quieter and more enviromentally friendly and the exaust won' stink or at least won't stink as much. I have a fuel injected '65 Impala and I'm considering cats because even my clothes stink after driving it.
Peter
Old Mar 6, 2010 | 01:23 AM
LT1driver's Avatar
LT1driver
you guys complaining about smell must be youngstersback in the day when cats were unheard off you didn't notice smell because all cars that way....sidepipes, 427, solid cam, headers, smell no problem, only power
Old Mar 6, 2010 | 11:29 AM
87SAM's Avatar
87SAM
You also have to remember that today’s gasoline chemical makeup is far different than it was during those (fun) times.
