Damaged Air Filter Question
Old Mar 1, 2010 | 09:14 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Default Damaged Air Filter Question
I have an old Halltec Tric on my 1999 coupe. The Tric was originally provided with a "wedge" air filter.
Mine must have been pretty beat up at some point one of the shops I utilize found the pne pictured and installed.
I am wondering if the chewed up flange and the split on the top (as seen in the pic) are causing my system any issues?
I just saw the condition of this thing and it must have been on now for a while. Am I asking for trouble leaving this on?
Thanks for any guidance/suggestions.
Old Mar 1, 2010 | 09:26 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Looks to me like that would cause an air flow issue with that split on the filiter, I dont think the flange would cause a huge problem because the MAF would go in the flange and then clamp down.
Old Mar 1, 2010 | 09:47 PM
AnteVenom's Avatar
AnteVenom
Thanks for your reply. I doubt it's causing an air flow issue since it is located way before the MAF but I could be wrong and I guess it could allow unfiltered air into the mix.
WIth the TRIC there is an S shaped aluminum piece that sits between the MAF and the filter and snakes through a hole made in the radiator shroud.
Thanks again for your ideas!
Old Mar 2, 2010 | 09:38 AM
AnteVenom's Avatar
AnteVenom
ttt
Old Mar 2, 2010 | 10:19 AM
bobby777's Avatar
bobby777
Take a Tube of silicone and slather it all over the crack--than take a roll of Duct Tape and wrap it--no more air leak!
Old Mar 2, 2010 | 11:44 PM
Dave68's Avatar
Dave68
If you pull or push on the split area, does it open up to the inside? If it does, it may not be sealing, even after the clamp is tightened. I would trash it if it were mine. In the meantime, some 3M gasket adhesive could bond the split areas together.
Old Mar 5, 2010 | 07:18 AM
AnteVenom's Avatar
AnteVenom
ttt
Old Mar 5, 2010 | 11:19 AM
hotwheels57's Avatar
hotwheels57
If you plan to continue using that air intake assembly and decide you want a new filter, contact S&B FILTERS (CA).
They do/did make the filters for HALLTECH. The also supply the filters for other manufacturers, including the oil/cleaning kits. Their oil/cleaning kits offer two colors of oil depending on the color of the filter media.
They can make you a custom filter to your specs, including media color, rubber end caps, colored end caps, or chrome end caps. If you send them your damaged filter, they'd probably be able to identify the specific specs in their database.
The turn around time is quick, the cost isn't much more (if that) than buying one off the shelf if it's still even available from HALLTECH.
Old Mar 5, 2010 | 04:11 PM
AnteVenom's Avatar
AnteVenom
Thanks for all the great replies! I will check out the S&B suggestion!
To Damaged Air Filter Question
