Lights on Hvac controls
Old Mar 2, 2010 | 10:22 PM
TexasVette01's Avatar
TexasVette01
7th Gear
Default Lights on Hvac controls
I can see anything at night time because it doesnt light up.
Whats the fix?
Old Mar 2, 2010 | 10:26 PM
lucky131969's Avatar
lucky131969
Whats the fix?
Are you saying the digital display on the auto A/C control panel is dark.....nothing displayed?
Old Mar 2, 2010 | 10:28 PM
lucky131969
http://forums.corvetteforum.com/c5-t...splay-fix.html
Old Mar 2, 2010 | 11:49 PM
chargedc5's Avatar
chargedc5
there is also a digitalguy who fixed mine for around 50.00 plus he shipped it back within 48 hours and he gives you a 5 year warranty! I did the self fix the first time but then needed lights because they went out so I just sent it to him!
Old Mar 3, 2010 | 10:05 AM
Dave68's Avatar
Dave68
I believe that's the link I used before diving into mine. I used it as an excuse to buy a new Weller soldering iron with adjustable temperature setting and found the solder on the inner board (shown in the link) to be cracked in a few places. All it took was some resoldering (make sure the solder tip has solder on it or the board solder may wick up) and my display is now at full brightness.
You can use my shifter removal procedure to get to the HVAC box. Then it's just a matter of removing some screws and the box containing the inner PC board can be removed.
http://www.conceptualpolymer.com/BPP...%20Install.pdf
Old Mar 3, 2010 | 10:08 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
or you can PM tstar and he will hook you up
Old Mar 3, 2010 | 10:58 AM
TexasVette01
7th Gear
The digital works. Just nothing else lights up
Old Mar 3, 2010 | 11:42 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
http://www.mcmaster.com/#1505k414/=6241tt
To Lights on Hvac controls
