My buddy just fired his 03(not for very long),after sitting a month,and it is showing 0 oil psi.-it had been sitting 2 months prior to that-apparently it sounded fine.
So these sensors are problematic?
Is there a quick troubleshoot?
Dominic
Dominic
A zero indication is very uncommon. Most OPS fail at max indication 80 analog; 130 digital.
I had two go bad, and they both went to 0 eventually, and I believe I got a code for it as well, but before they went they both acted a little crazy, and maxed out... then went to 0.
