2000 Check engine LIght / Fuel sensor?
Old Mar 5, 2010 | 09:10 AM
sts57c5's Avatar
sts57c5
Default 2000 Check engine LIght / Fuel sensor?
This morning when driving to work my check engine light came on? I also noticed that on my DIC the guage that shows the amount of miles to empty gas tank was moving from 249 back to 195 back to 125 and would not stay fixed on one number? Also yesterday I did fill my car up with gas. When I parked i did check unscrew the fuel cap and put back on but that didnt seem to help the problem. Any suggestions as to what might be causing the problem?
Old Mar 5, 2010 | 12:51 PM
BigGun's Avatar
BigGun
Why don't you check the codes using the DIC and post them? This will probably tell you the reason for the check engine light. B\G
Old Mar 6, 2010 | 11:24 AM
sts57c5's Avatar
sts57c5
10 pcm p1415 h c
secondary air injection system bank 1
here it is
To 2000 Check engine LIght / Fuel sensor?
