Cold air Intake???
Old Mar 12, 2010 | 03:36 PM
dbaker's Avatar
dbaker
Lot's of opinions....no one knows what is truly best since we all have diff levels of mods.
I run the VR w/Power Duct on my 02Z.To straighten out this increased air flow and to avoid the dreaded lean codes,I also put in the Halltech Honeycomb MAF screen.
No lean codes and runs great.
\db2
Carolina
Old Mar 12, 2010 | 04:42 PM
RDnomorecobra's Avatar
RDnomorecobra
Originally Posted by Dave68
I did something a bit different. Instead of isolating the cold intake air from the engine bay, I direct it (via polycarbonate scoop) through a stainless steel mesh screen and into and around my Halltech warhead filter. The engine draws in cold air and my engine bay stays cool, which also assists my catch can in trapping water along with oil.
you got any info/pics on that?
Old Mar 12, 2010 | 07:41 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Originally Posted by mel3535
some people tell me they are useless others say they are the best cheap upgrade, what do you guys think? which one is the "best"?
use the search feature
Old Mar 12, 2010 | 09:44 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
ok after reading all this, i will probably go with the black wing
i only have couple of more questions
1; how hard is blackwing to install?
2: CAI,more specifically the blackwing do any damage to my engine or anything else?
3: and like you said in warmer weather it will cause me to lose HP but do i still get better mileage in the city or highway regardless of weather condition if i take it easy and drive slow and steady?
The Blackwing is easy to install and will not cause damage to your engine as long as you install it properly since the filtering media is of the highest quality which is the main reason that I chose it along with its OEM fit and finish.
After removing the stock airbox, carefully and firmly press the MAF completely onto the Blackwing and tighten the clamp. This will insure that he grommets at the top of the radiator cover line up with the holes in the Blackwing. The airbridge will fit the Blackwing like it fit the stock airbox.
Once you have it all pressed together, insert the grommets into the Blackwing. Using silicon spray on the rubber grommets and on the frame posts will make the assembly easier.
Once the MAF and Blackwing are together, press the entire unit onto the posts in the front frame. Then press the airbridge down into place and install the coupler.
Installation instructions:
http://97vette.com/howto/blackwing/index.html
Old Mar 13, 2010 | 05:44 AM
Big_George_S's Avatar
Big_George_S
While I would agree with you and in fact did just what you are about to do 4 years later when Calif asked me to Smog the car I could not get the blackwing to pass inspection. I opted to change out the Blackwing for the K&N FTPK which is CARB exempt i.e. you can get a little sticker that says that K&N and tested and asserts that the product does not change the characteristics of the car's smog system.
Here is the California Air Resource Boad link that gives you access to what is legal in CA. I found it useful in my search for answers.
http://www.arb.ca.gov/msprog/aftermk...ry.php.:smash:
Old Mar 13, 2010 | 01:10 PM
mel3535's Avatar
mel3535
Since u had both, in terms of performance which one was better?
Old Apr 16, 2010 | 10:17 AM
davesabo's Avatar
davesabo
rboineau said---then cut oval openings, not too big, in the TOPS of the fog-light shrouds..
Can you explain this further? is there a DIY threat? do you take the shrouds out of the car? thanks for the info....
Old Apr 16, 2010 | 11:08 AM
SDLS1Rider's Avatar
SDLS1Rider
I've read the thread and see that the OP has decided on a Blackwing. So he may want to ignore the rest.
I would consider the Callaway Honker. It is a high quality aftermarket item, and a novice like me installed it in a long morning. It does require cutting the radiator shroud. But as stated earlier it is a true Cold air intake. Best of all it is CARB certified. Just install it and forget. I'm not sure of the performance increase since the dyno was done after the install and I didn't have any base number. But when I jumped on it the rear tires started to break loose with traction control!
I think Callaway's Honker CAI will give you the best of all worlds.
Old Apr 16, 2010 | 03:12 PM
Trios's Avatar
Trios
There are essentially two groups and at least one intake system that lies in between.
The first group of intake systems or filter elements will allow performance to degrade as underhood temperatures rise. This occurs as vehicle speed is reduced due to various reasons such as traffic, construction, long tube headers, etc. Your engine's computer will retard timing to prevent predetonation and the result can be a 10 HP loss - that's not small change. Typical "warm air" intakes are the Blackwing, Halltech Stinger, and Volant twin filter.
Next, we have cold air intakes like the Callaway Honker, BPP Vortex, and Vararam. These systems allow the engine to pull in outside air and thus prevent horsepower degradation during slow-moving driving. Unfortunately, (non-Z06s) they do nothing to prevent headers and the engine itself from heating up the engine bay to a point where interior computers, plastics, and rubbers (not to mention the battery) will have shortened lives.
The K&N FIPK system is half way between the first and second categories. I call it a semi-cold air system.
Where does the BBK CAI fall?
Old Apr 16, 2010 | 03:22 PM
Dave68's Avatar
Dave68
The BBK system looks very similar to a Blackwing or Halltech Stinger in that it is not a true cold air intake. It pulls in warm-to-hot engine bay air. If you have this system, you'd do well to do my CAI mods, open up the fog light panels, or both. Otherwise, you gained HP will drop off quickly during slow-moving conditions.
Here's what the BBK system looks like:
http://www.bbkperformance.com/produc...ntake-kit.html
dave
Old Apr 16, 2010 | 03:30 PM
Dave68's Avatar
Dave68
1. It's a very easy install, as is the Halltech Venom
2. Instead of getting 350,000 miles out of your engine, you may get only 250,000 miles. In general, higher flow = less filtering, especially at high rpm.
3. Your mileage will not change significantly when driving moderately. You will burn more fuel during agressive driving.
Old Apr 16, 2010 | 03:40 PM
Trios's Avatar
Trios
dave
Do you have a build thread for your modification?
Old Apr 16, 2010 | 05:45 PM
  #33
hawk4077's Avatar
hawk4077
With the blackwing should one put a hood seal on to prevent water from getting into or on the filter?
Old Apr 16, 2010 | 05:55 PM
  #34
postwhore's Avatar
postwhore
MAYBE IT'S JUST ME BUT.......
Originally Posted by hotwheels57
Old Apr 16, 2010 | 07:51 PM
  #35
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
If you want to FEEL the effect before buying one just take your stock air cleaner off and go for a short ride (not on a dirt road, of course!) You will immedately feel the added pull of the car.
Old Apr 16, 2010 | 09:56 PM
  #36
Big_George_S
is K&N FIPK Air Intake Kit any good? Compared to Blackwing or VaraRam?
It is the only one you can use in CA and be CARB compliant.
Old Apr 16, 2010 | 10:10 PM
  #37
chuffo302stang's Avatar
chuffo302stang
then do the ZIP TIE MOD
Im not sure if it made any HP gains but it had a seat of the pants gain.
also ran a 12.91 @109 with nothing other than a Ti catback
To Cold air Intake???
Old Apr 16, 2010 | 10:50 PM
  #38
AU Eagle's Avatar
AU Eagle
St. Jude Donor '08-'09-'10-'11, '14
So far happy with the Vararam. Definitely seems to pull harder at speeds over 55. Install was a pain, but the effort was worth the gain in my opinion.
Old Apr 17, 2010 | 01:12 AM
  #39
Dave68's Avatar
Dave68
I sure do:
http://www.conceptualpolymer.com/Rad...op%20inst..pdf
Actually, the Callaway Honker also is C.A.R.B. approved, at least for non-Z06s.
The FIPK is in between the Blackwing and Vararam.
Old Apr 17, 2010 | 02:43 AM
  #40
ls2alex's Avatar
ls2alex
what about the hurricane??
