convertible top not functioning properly
Old Mar 7, 2010 | 02:17 PM
bigvx5's Avatar
bigvx5
Default convertible top not functioning properly
when i lift it to put it back up the rear section is not popping up so the boot cover can go back in place..anybody had this problem and what /where do i check to fix it?car is a 99,not sure if that makes diff..
Old Mar 7, 2010 | 06:39 PM
65GGvert's Avatar
65GGvert
When you lift the front portion (nearest the windshield) that releases the rear section. You lift that, close the lid, lower the rear and then lower the front and latch. If you are not lifting that front portion after you raise the top out of the storage area, the rear will never release. If you are lifting the front and the rear is still not releasing, you do have a problem with the top frame.
Old Mar 7, 2010 | 07:24 PM
bigvx5's Avatar
bigvx5
i got it..guess i was lifting the rear too late..
To convertible top not functioning properly
