Changing gauge cluster, saving current odometer?
Old Mar 12, 2010 | 09:41 AM
minitech's Avatar
minitech
Default Changing gauge cluster, saving current odometer?
I would like to swap out my gauge cluster for another one. I have both and they are both the same except one has gauge bezels. I just want to swap them and keep same car data on both.
Is there something I can swap between them to save odometer on each?
Old Mar 12, 2010 | 10:23 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You'll need to contact a speedometer repair place and provide them with lots of documentation due to the legalities involved. Some have done this through dealers who can send them out for you, therefore providing an extra measure of legality protection for you. You normally cannot do this by yourself and I wouldn't recommend trying.
Old Mar 12, 2010 | 10:47 AM
minitech's Avatar
minitech
This is something I read somewhere here and can't find again. I thought I could change a circut board between them to preserve it.
Legal wise it is completely legal as I am trying to preserve same odo on same car.
Old Mar 12, 2010 | 10:55 AM
lucky131969's Avatar
lucky131969
Yep, you even posted in the thread.....
Read post #5
http://forums.corvetteforum.com/c5-t...ster-swap.html
Old Mar 12, 2010 | 06:29 PM
minitech's Avatar
minitech
Read post #5
Thanks, there is the answer. I do post when I can if it helps anyone else out. But don't always recall everything or at least where it is.
Old Mar 12, 2010 | 07:51 PM
lucky131969
Yep, your memory served you correctly.....would be cool if you did a thread on the odometer board swap.
Old Mar 13, 2010 | 04:08 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! I agree!
BC
Old Mar 13, 2010 | 09:40 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you can take apart the cluster, just remove the black frame the bezels are attached to and transfer that to the new cluster
I will post any questions to help w/ the process
it's very easy
the board swap takes about 15 minutes if you want to go that route
Old Mar 13, 2010 | 11:01 AM
minitech's Avatar
minitech
I'm about to do the change over. Situation is I have 2 cars, both have gauge bezels but one has stainless and one has plastic. I think the stainless bezels look better. I am needing to get one out anyway to do a bit of LED repair it needs, probably a loose base from when I put LEDs in.
I just thought the board swap would be cleaner and not have to pull needles from the gauges.
Old Mar 13, 2010 | 12:09 PM
minitech's Avatar
minitech
it's very easy
Any pics of the board swap? Is it the small circut board next to the main one?
Old Mar 14, 2010 | 01:12 PM
SteveDoten's Avatar
SteveDoten
It's easy, if you need help give me a call, # is in profile
Old Mar 14, 2010 | 01:13 PM
SteveDoten's Avatar
SteveDoten
Actually, yes on the pics, send me an email; just realized they are on the phone
To Changing gauge cluster, saving current odometer?
