Need Clutch Feedback.
Old Mar 17, 2010 | 11:25 PM
jpandes's Avatar
jpandes
Two local speed shops recommended the LS7 for my H/C 03Z DD w/ 451 rwhp & 405 ft./lbs.
However, one of them suggested going with a lighter flywheel and one recommended against going with the light FW. I went with the LS7 fw and new slave and bearing.
I did end up with a very slight vibration No biggie.
Old Mar 17, 2010 | 11:51 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Originally Posted by jpandes
Two local speed shops recommended the LS7 for H/C DD w/ 451 rwhp & 405 ft./lbs.
However, one of them suggested going with a lighter flywheel and one recommended against going with the light FW. I went with the LS7 fw and new slave and bering.
I did end up with a very slight vibration. No biggie.
See I keep getting the same thing. Looks like I might just flip a coin and see what happens
Old Mar 18, 2010 | 05:56 AM
AF Vette's Avatar
AF Vette
I have 400 RWHP and a monster 2, it holds fine and the chatter went away after the break in period. So far its handled what Ive thrown at it including hard downshifts
Old Mar 18, 2010 | 08:39 AM
kp1's Avatar
kp1
I have had good results from the ACT single disc mated to a RAM billet FW. I think it's rated to something like 750 lb/ft. No chatter at all ever and it will hook when you let it out. I've got 350 lb/ft of torque at 2200 RPMs and I peak at 460 lb/ft. It has performed flawlessly. It does have a heavier pedal than the stockers.
I give the ACT.
Old Mar 18, 2010 | 02:33 PM
0331MARINE's Avatar
0331MARINE
Thanks alot guys. Now I have to pick
Monster II
Spec I or II
Old Mar 18, 2010 | 06:25 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Originally Posted by NVTHIS
What about textralia?
I have one and it chatters like a cold dog. Ive got 10-12000 miles on it, four years old, and first gear is starting to slip.
It grabs great, but chatters off the line.
I had the LS7 clutch for a couple months and it was sweet, till it crapped out on me
Old Mar 18, 2010 | 06:34 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Which textralia do you have? i have the OZ700 with the z-grip disc which I have heard doesn't chatter like the x-grip. I don't know if mine chatters or not yet as my car is still torn apart.
Old Mar 18, 2010 | 06:37 PM
mygiftmycurse's Avatar
mygiftmycurse
For every1 who has gone with an aftermarket clutch/flywheel...do you have any issues with the pedal sticking like a bunch of guys with the stock one has?
Old Mar 18, 2010 | 07:05 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Not yet!!!!
Old Mar 18, 2010 | 07:06 PM
jpandes's Avatar
jpandes
Bummer dude! I hope my LS7 clutch tdoesn't crap out on me. I have similar RWHP as you with about 30 fewer ft.lbs. I sure as hell don't want to pay for R&R for another clutch. That would really suck!
BTW, the LS6 with 30k miles was sticking to the floor after one WOT run. The new LS7 works great. No slippage or sticky clutch.
Old Mar 18, 2010 | 10:40 PM
froman's Avatar
froman
I would still look at diamond clutches.
Old Mar 18, 2010 | 11:44 PM
0331MARINE's Avatar
0331MARINE
Like I said man I have never heard of them, and I cant find any feedback about their clutch set up. Thanks though Ill keep looking
Old Mar 18, 2010 | 11:52 PM
  #33
hatewhatownsyou's Avatar
hatewhatownsyou
im going to go with a monster stage 2, all i hear is good things about them. i was going to go with a spec, but there are to many bad stories about them
Old Mar 19, 2010 | 12:06 AM
  #34
0331MARINE's Avatar
0331MARINE
See I hate picking. I have heard good and bad things about both. Price wise it would end up being about the same once I buy everything.
Old Mar 19, 2010 | 06:27 AM
  #35
phils C5 vette
It shouldnt crap out on you. A friend of mine on here has the same RWHP as me with the LS7 clutch. He had his installed at the same time, and his never give him a problem.
My tex is OZ700. Grips like a ****, but within the last month or two, I must have burned a spot on the flywheel to cause the little slip onder load. The only bad thing I can stay is the chatter, and that's just the clutch trying to grab and go in first gear.
Old Mar 19, 2010 | 08:29 AM
  #36
dcd58's Avatar
dcd58
I Have the same #'s as you - well close 411/399
I had ECS do my work and they installed a RPS Carbon/Carbon clutch system in the car. WOW is all I need to say! You should really consider this clutch, IMO
Old Mar 19, 2010 | 11:31 AM
  #37
gleds's Avatar
gleds
Originally Posted by mariofromnewyork
I have the Centerforce DF and at its price point it was a no brainer. Both my buddy and I have 450 rwhp and no issues. A little chatter during brake and a nice firm pedal thru the motion really lets you feel what the clutch is doing.
Also i called the CF tech guy and he spent a half hour on the phone with me and i say if you have the time call, he really schooled me on clutches/driving style. Taught me a bunc!
Mario
I second Centerforce DFX. A little chatter during break in but drives as easy as stock now and holds my 469rwtq great. I am using the Gripforce F1 flywheel and it only cost $200.
Tip if you use the Centerforce: use new oem flywheel bolts
To Need Clutch Feedback.
Old Mar 19, 2010 | 12:58 PM
  #38
0331MARINE's Avatar
0331MARINE
You are the first person I have seen using the F1. I take it it does pretty good? I was waiting to see if anyone was using it. Now that gives me more ideas
Old Mar 19, 2010 | 01:23 PM
  #39
hatewhatownsyou
as if there are not enough options lol
Old Mar 19, 2010 | 04:50 PM
  #40
0331MARINE's Avatar
0331MARINE
Tell me about. I think I have my mind made up and then something else pops up. and to think this all started with a CAI and Stingers
