Ticking Noise please help!
Old Mar 17, 2010 | 02:23 PM
Tims02's Avatar
Tims02
Default Ticking Noise please help!
Hey guys.. I installed a new cam, heads, injectors, U/D pulley & Ported TB. I've always heard a ticking noise so I changed the springs and lifters but still have that same ticking noise and it seems to be getting worse. Anybody have an idea what this could be? Thanks guys.
Old Mar 17, 2010 | 09:25 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
If the ticking sounds like a sewing machine on steroids its your RR!
Mario
Old Mar 17, 2010 | 09:29 PM
Tims02's Avatar
Tims02
Sorry for my ignorance but what is RR?
Old Mar 18, 2010 | 02:01 AM
blazer427X3's Avatar
blazer427X3
How old are your plug wires ? One thing to try is to start the car in a dark garage or at night, lift up the hood and look for anything arcing.
I've also heard that an injector can make a tick or snapping noise when its clogged.
Old Mar 18, 2010 | 08:49 AM
kp1's Avatar
kp1
The valve train is noisier with the larger duration higher lift cams.
How did you determine push rod length? Going to a cam with more lift means you probably have a smaller base circle and need a longer push rod. You can't be certain unless you check a few of them to see what your lifter preload is. Too much preload or not enough preload = valve train is more noisy.
It all depends on the heads, gaskets, and cam you mated together. Ya gotta check it.
Old Mar 18, 2010 | 11:16 AM
a/c man's Avatar
a/c man
could be ex leak!
Old Mar 19, 2010 | 09:23 AM
Tims02's Avatar
Tims02
Hey guys thanks for the replies.. I used a pushrod lenght checker to determine the length of the pushrod I needed. I'm running a Torquer III cam with a lift of .647"/.598". The only thing that I still have stock is the Roller Rockers which I'm lookingto buy here very shortly. The motor only has about 400 miles on it and runs very strong except the damn ticking noise. All the plugs and wires are new so I'm kinda ruling thoses out at the time but I'll keep ya posted on any findings. Thanks Again..
Old Mar 19, 2010 | 11:47 AM
KOZ's Avatar
KOZ
The ticking noise I tracked down in my car was an exhaust leak at the headers. Was weird that the noise came and went depending on the temp of the motor. Go figure...
Old Mar 19, 2010 | 02:09 PM
Tims02's Avatar
Tims02
KOZ..I know what ya mean! The first thing I checked was the exhaust. I was hoping for an easy fix! My next question is do I go with an adjustable or non-adjustable Roller Rocker setup?
Old Mar 19, 2010 | 02:55 PM
wcsinx's Avatar
wcsinx
Is it a ticking or a chattering? As in does it seem to happen once per engine revolution (or ever other revolution) or is it much faster than that? If the latter, then you may just be hearing the classing "sewing machine" sound of a built up top end. If the prior, then I'd start by looking real closely at those rockers as you say they're the only original parts left and they are a common failure point. Make sure you don't have any puked out rocker bearings.
Get yourself one of these...
http://www.harborfreight.com/cpi/cta...emnumber=41966
If you don't already have one. They are a lifesaver when it comes to tracking down noises. You just put it on, then poke that probe all over the valve covers with the engine idling. If one of them is awry you'll know REAL quick.
Old Mar 19, 2010 | 03:08 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Tims02,
How about recording a wav file and posting it? You can do it with most any labtop computer.
Old Mar 21, 2010 | 04:21 AM
-DLS-'s Avatar
-DLS-
Make sure your pushrods are at the correct length and that you have tightend everything down correctly.
After that, what some users on LS1tech found, is that a bad seating of the oil ring on the pump will make the valvetrain tick from the drivers side #7 cylinder. Maybe a long shot but I'm sure that was a PIA diagnosing that problem.
To Ticking Noise please help!
