Cooling system question
Old Mar 19, 2010 | 09:54 AM
dchev's Avatar
dchev
Default Cooling system question
I have an 2004 stock C-5 with 28k on it. I plan to change the Dex-cool this spring. How often should the radiator hoses and thermostat be changed? I have had no trouble with any of the system, I just want to do some PM.
Thanks for your suggestions,
dchev
Old Mar 19, 2010 | 11:59 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by dchev
I have an 84 stock C-5 with 28k on it.
First of all if you have a C5 Corvette, it can't be a 1984. That would be the first C4 model year. Which year do you actually have?
Old Mar 19, 2010 | 12:16 PM
lucky131969's Avatar
lucky131969
2004 according to the OP's sig.........
Old Mar 19, 2010 | 02:26 PM
dchev's Avatar
dchev
oops!!!! I have a 2004 vette. Sorry about that. My nimble fingers failed me once again.
Old Mar 19, 2010 | 02:36 PM
Cybermind's Avatar
Cybermind
dchev
According to the GM service manual:
If the coolant looks clean and clear, you only need to drain and refill with 50/50 Dexcool and distilled water.
If the coolant looks to be contaminated, dirty, murky, etc. then you will need to flush your system completely and refill with 50/50 Dexcool and distilled water.
That's it. There is no required preventive maintenance on the thermostat or hoses unless you are noticing brittleness or cracking. Since you have 2004, I would't worry too much about your hoses. I wouln't worry about your thermostat either. It will give warning signs if it starts to act up.
Old Mar 19, 2010 | 03:14 PM
dchev's Avatar
dchev
Cybermnind, Thanks for your reply, The hoses feel like new with no brittle or soft spots. Not having to change them won't hurt my feelings or knuckles!!
Tks, Dave
Old Mar 19, 2010 | 05:39 PM
Quicksilver Vert 01
A simple coolant change should be all it needs for now.
Old Mar 20, 2010 | 10:05 AM
dchev's Avatar
dchev
Quicksilver, Thanks for your reply,
Old Mar 20, 2010 | 01:58 PM
TEXHAWK0's Avatar
TEXHAWK0
Even though Dexcool is supposed to last for 5 years, I never let antifreeze go over 2 or 3 years. Since I change a little early, I generally just drain what I can, and refill with 50/50 mix, and mine has always come out clean.
I would not mess with the thermostat unless you have a problem.
I also like to change the antifreeze while the engine is cold, so I don't worry about hot antifreeze, and I do not leave a hot engine without coolant in the water pump and thermostat. It should not matter, but I have had cars where I was not having a thermostat or water pump problem, and I left the coolant out long enough for the thermostat to dry out, and it ended up sticking, not to mention developing a pump leak.
I generally think about changing the main hoses after 5 or 6 years, but I have had cars where the smaller hoses lasted twice that long. I also have a 2004, and it still has the original hoses, but I have changed the coolant twice. (got the car in 2003)
Old Mar 22, 2010 | 06:33 PM
dchev's Avatar
dchev
Texhawko, Thanks for your input, I will change the Dex-cool and keep an eye on the hoses and will probably change them in a couple of years with another Dex-cool change.
dchev
Old Mar 22, 2010 | 08:54 PM
Bill Dearborn's Avatar
Bill Dearborn
I have been changing the DexCool in my cars at the 5 year mark. Have been doing this since my 97 reached the 5 year mark. No problem on any of them. The old coolant looked like it was brand new when I took it out. When I do the change I use drinkable water which is what the owner's manual and several versions of the service manual recommend. Just make sure all of the old coolant is out of the engine. The only way to do that is to drain, refill with water run the engine till the thermostat opens and drain again and repeat until the drained coolant is clear water. Once that is done add the proper amount of full strength Dex and top off with water. 50/50 Dex shouldn't be used on the refill as there is at least two quarts of water in the block and it will dilute the mix. Not a big issue if you live where it doesn't get very cold but if your car is stored in a non heated garage in certain northern climes the coolant could freeze just because of that small error.
Bill
Old Mar 23, 2010 | 09:28 AM
dchev's Avatar
dchev
Bill, Thanks for your input, dchev
Old Mar 23, 2010 | 10:03 AM
wcsinx's Avatar
wcsinx
I do hoses on a 5 year schedule whether they look like they need it or not. I too have seen them go much longer than that. But it's a cheap and easily replaced part, and if they pop they can leave you stranded.
I bought my '02 in '08 and one of the first things I did was to replace the belts and hoses. They all looked fine inside and out with no rot or cracking, but now I have that piece of mind for 5 more years.
Old Mar 23, 2010 | 10:32 AM
lucky131969
I used to be on that schedule when I lived in Tucson. The extreme dry temps out there really does a number on rubber. Same with air filter in the desert southwest.........change frequency doubles.
To Cooling system question
