RED COUPLER? NEED HELP!!!
Old Mar 11, 2002 | 10:11 PM
Dale RED 98's Avatar
Dale RED 98
Default RED COUPLER? NEED HELP!!!
Hey! I'm trying to install carbonfiber air duct and Red Coupler. Coupler is so tight on the throttle body end I can not get it on! Any Help? Came from LAPD .they are not open at this time. THANK'S for any HELP!!! :confused: :mad
Old Mar 11, 2002 | 10:16 PM
YO-EL's Avatar
YO-EL
Default Re: RED COUPLER? NEED HELP!!! (Dale RED 98)
Try some wd-40 on a rag & wipe the inside of the coupler & the lip of the throttle body. The coupler will stretch over it. If you have to, put the coupler on the TB first, then you can work it from the inside. The other end should fit on the duct with no problems.
Old Mar 12, 2002 | 01:07 AM
Dale RED 98
Default Re: RED COUPLER? NEED HELP!!! (indypace78)
Thank's indypace! Got it done with WD 40 and alot of sweat! Just seemed that nothing would line up!Must be ME!! THANK'S AGAIN!! :cheers: :eek:
Old Mar 12, 2002 | 06:52 AM
vettenuts's Avatar
vettenuts
I used a little silicone grease like you use on the spark plug boots. Figure I will eventually have to remove it so I don't want to have it stuck there.
Did you just put the carbon fiber end over the metal on the MAF with a clamp?
Old Mar 12, 2002 | 12:23 PM
Dale RED 98
Default Re: RED COUPLER? NEED HELP!!! (vettenuts)
No!I used the stock rubber boot.Was I suppose to remove the rubber boot? Thank's for any info!!!1 :cheers:
Old Mar 12, 2002 | 03:53 PM
vettenuts's Avatar
vettenuts
Don't know, maybe I screwed up. I slid the air bridge right onto the MAF since it had the key on the side and the air bridge didn't have a rubber boot on my 02.
Old Mar 12, 2002 | 03:56 PM
Scruffy's Avatar
Scruffy
The air bridge should couple directly to the MAF. No boot in between.
Old Mar 12, 2002 | 04:35 PM
Dale RED 98
Thank's guy's!!! Your right about the boot. I called Shawn at LAPD this morning and he told me to lose the boot.It would be nice if the company that make's the air duct would put info in with them! Shawn is a GREAT GUY!!!THANK'S AGAIN :cheers:
Old Mar 12, 2002 | 11:29 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
You should get 2 hp with RED!
Old Mar 13, 2002 | 01:15 AM
psychokiller's Avatar
psychokiller
Default Re: RED COUPLER? NEED HELP!!! (wallstAL)
And 3 with yellow!
Rice proven! :D
To RED COUPLER? NEED HELP!!!
