Block & cam question
Old Mar 21, 2010 | 10:03 AM
vetteracerx's Avatar
vetteracerx
Default Block & cam question
Is a 1998 LS1 bare block interchangable with a 2001 LS6? Mine is cracked. Also what would be a mild upgrade for the cam? Thanks guys
Old Mar 22, 2010 | 01:12 AM
vetteracerx
anyone?
Old Mar 22, 2010 | 11:41 AM
vetteracerx
I made a deal to get an LS1 block Sunday. Does anyone know if it will interchange with my 01 LS6? I plan on a basic rebuild but I would like a better cam. Any ideas?
Old Mar 22, 2010 | 03:39 PM
2079's Avatar
2079
From what I read they are basicaly the same so I'd say yes. Hopefully others will comfirm this and give you additional info.
As for a cam 224-228 581/588... LSA 114 is a very popular one and is considered small by many ,it will provide lots of low end torque and HP and will maintain close to stock divability whit the addition of a loopy sound. A good tune is required.
Consider LT's at the same time.
Old Mar 22, 2010 | 03:40 PM
vetteracerx
thanks
Old Mar 22, 2010 | 06:27 PM
2079's Avatar
2079
I will this up for you.
I would like to had that you have very good heads but whit any cam upgrade that you will consider you will have to replace you springs as they are only good for up to .570 lift and they are not all that great anyway " they brake ".
Old Mar 22, 2010 | 06:54 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Here is a quote from an article on Wikipedia.
"The LS6 shares its basic block architecture with the GM LS1 engine, but other changes were made to the design such as windows cast into the block between cylinders, improved main web strength and bay to bay breathing...."
http://en.wikipedia.org/wiki/GM_LS_engine
Hope this helps.
-Cameron
To Block & cam question
