Power seat won't move
Old Mar 23, 2010 | 12:44 AM
Muchie69's Avatar
Muchie69
Default Power seat won't move
I removed both seats of my 2000 convertible, driver's side to repair torn bottom and the passenger's side to repair the circuit board under seat. Passenger side is not done yet so I just installed the driver's seat but have no power. Do both seats have to be installed in order to work or should they work by themselves? Thanks for your help.
Old Mar 28, 2010 | 11:18 PM
pmsjr's Avatar
pmsjr
As far as I know they should work all by themselves. I've got my passenger side out right now and my driver's side still works.
Pete
Old Mar 29, 2010 | 12:12 AM
byronhunter's Avatar
byronhunter
Have you checked Fuse #4 in the IP Fuse Block? That would be the first thing to check!
Old Mar 29, 2010 | 01:15 AM
DeeGee's Avatar
DeeGee
I'd say the only things its likely to be are a bad connection at the seat connector or a blown fuse which is easily done. When you get the other seat back in, (its fused on #3 on the same block), if it works then the problem can be isolated to the drivers seat itself.
To Power seat won't move
