g5x3 CAM???
Old Mar 26, 2010 | 08:42 PM
ctusser's Avatar
ctusser
Originally Posted by Venomous
Do the 112LSA as you will have a much slower chop to the exhaust and it will bring in power later in the band, whereas a 114 will be closer to the stock 116 LSA and not have near the chop of the 112. The 114 will give you power lower in the RPM band but fall off sooner. The 112 will not have as much Grunt down low as a factory cam, but after about 2200 watch out as Screamin Demon comes though all the way to 6800! Been there and done it on a 111 LSA 230
You've got the chop description right, but the description of where the power comes on with a 112 vs a 114 completely backwards.
Old Mar 26, 2010 | 09:39 PM
black98c5's Avatar
black98c5
Originally Posted by truckerc6
Did you like the cam? This will be my first one so i'm trying to pick the right one...........
The cam was great! Made great power and lots of lope on the 112lsa. Only reason for switching was because I went F/I. My current cam is nearly identical, but with a 115lsa...which still lopes hard. You won't be dissapointed!
Old Mar 27, 2010 | 09:23 PM
truckerc6's Avatar
truckerc6
Default Will the 114 sound good with a very good lope
Please post videos if you have them. I went to order it today and i was told that i have to do different headers to run the 112. So i guess i will do the 114 if it will sound awesome im the car.
Please give me your advise!
Old Mar 28, 2010 | 12:00 AM
TurboBerserker's Avatar
TurboBerserker
I have the G5x3 114 in a 427 and it lopes a bit. Great power all over the band. I'm running 245cc heads too with 1 7/8 ARH headers. I get lots of thumbs up at lights and after some spirited acceleration.
Old Mar 28, 2010 | 08:36 AM
AU N EGL's Avatar
AU N EGL
if you want some shake with those 112 LSA cams, use solid motor mounts.
Old Mar 28, 2010 | 02:00 PM
corvette8189's Avatar
corvette8189
I never heard of that. i had the x3 112 for almost a year and i loved it. sounded awesome and ran great. with a good tuner i doubt you would even tell the difference between the two. im in the process of supecharging and am selling my x3 112, pm me if you want to.
Old Mar 28, 2010 | 09:06 PM
vmaquera's Avatar
vmaquera
I have the 112.
I love the choppier idle. It sounds great. With a good tuner, it is very driveable.
Old Mar 28, 2010 | 09:28 PM
truckerc6's Avatar
truckerc6
Are you running stock ls6 heads with the 112. I was told that i have to have new heads to run the 112
Old Mar 28, 2010 | 09:44 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have the G5X2 on 112 in my 70. I have not tuned the car fully yet. I just have not really had the time to get it done. I should just take it to someone and get it tuned.
Here is a video of the car idling in the driveway with no tune.
Old Mar 28, 2010 | 10:06 PM
corvette8189
Call Anthony at LG and he will tell you. But like i said i didnt have to flycut.
Old Mar 28, 2010 | 10:50 PM
truckerc6's Avatar
truckerc6
Just checking, i dont remember who i spoke with at lg. Pm me for the paypal
Old Mar 29, 2010 | 02:18 PM
GFCmgb71's Avatar
GFCmgb71
Originally Posted by DNAST1
I have the G5X3/114. Excellent choice! Lots of lope! Guaranteed to turn heads! With stock heads I made 407 RWHP. I now have AFR 205/90/90 combo making 470 RWHP with 4:10 gears
whoa you must get good traction
i got black98's on g5x3 on a 112lsa w/stock z06 heads and it screams.
PM me for some good vids sound+hard excelleration...
Old Mar 29, 2010 | 08:16 PM
  #33
truckerc6's Avatar
truckerc6
What are the specs on that cam?
Old Mar 29, 2010 | 08:23 PM
  #34
GFCmgb71's Avatar
GFCmgb71
238/242 .595/.609 i think thats close...
Old Mar 29, 2010 | 08:28 PM
  #35
scalemaster's Avatar
scalemaster
St. Jude Donor '09-'11-'12
how about the MS4 cam
thats what I want next
Old Mar 29, 2010 | 09:15 PM
  #36
TurboBerserker
I measured 237/246 .600/.609 on my 114lsa version
Old Mar 29, 2010 | 11:22 PM
  #37
truckerc6's Avatar
truckerc6
What are you going to do with your eg cam?
To g5x3 CAM???
Old Mar 30, 2010 | 05:32 PM
  #38
ttribe's Avatar
ttribe
Do a search on youtube for: c5zee .... I have videos on there with the g5x3 112 cam with 4 different exhaust combinations so you can get a good "feel" for it. (b&b bullets, stock ti, ghl bullet and corsa pacecar).
My 2003 z06, all stock motor (except cam/valve springs). LG "street" headers, callaway honker cold air. Made 437/405 at the tires with a 50lb twin disc clutch in the car.
I have done some highway roll races against other c5z ... even some with larger headers and higher duration camshafts and I have yet to have any pull on me. I am pretty happy with LG's stuff. Driveability is just fine for me.
Good luck!
Old Mar 30, 2010 | 06:28 PM
  #39
truckerc6's Avatar
truckerc6
thanks man, what are the specs on that g5x3 cam?
Old Mar 30, 2010 | 06:35 PM
  #40
corvette8189
From LG website
G5X1
228
232
.588
.574
112/114
G5X2
232
240
.595
.608
112/114
G5X3
2xx somewhere around 236
2xx somewhere around 242-4
.600
.610
112/114
