Startup Security Problem
Old Mar 28, 2010 | 11:08 AM
drdwallman's Avatar
drdwallman
3rd Gear
Default Startup Security Problem
I have a 2000 corvette automatic convertible with 22000 miles. Frequently when I start the car the security kicks in and tells me to "pull the key and wait 10 seconds". After that warning on the second attempt it tells me "service column lock". I can reset the problem by pulling the key opening and closing the car door and pressing the reset button. History on the car: I was getting water on the passenger side floor, we first thought it was a clog in the fan box drain and had that fixed? We later found out that it was a leak in the windshield. Fixed that and also had to repair the connectors to the computer module on the passengers side under the foot stop floor cover. Water rusted the connectors. What is the permanent fix or bypass of the problem? Thank You David
Old Mar 28, 2010 | 11:24 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
First off, you need to buy a CLB or Column Lock Bypass and install it right away. The udder drain on the HVAC gets plugged up and causes water/condesation to build up and eventually drain all over the BCM (Body Control Module) which is one of the units under the passenger floorboard. It controls just about everything not engine related and it communicates directly with the PCM (Powertrain Control Module). Without either one, the car will not even start. That BCM and its connectors needs to remain dry and clean. Note: do not diconnect it with the battery connected.
Old Mar 28, 2010 | 01:29 PM
drdwallman's Avatar
drdwallman
3rd Gear
Does the CLB disable other security features that are helpful to protect the car from theft?
Where can I purchase a CLB?
Old Mar 28, 2010 | 03:42 PM
dgrant3830's Avatar
dgrant3830
I believe its Corvettes of Houston or something similar to that who carries them. What it does is prevent the action of the locking pin engaging and if I remember correctly, it does this by not sending the steering column all the way down into the locked position. So yes, the steering lock is disabled but its better that than having it locked and unable to move the car.
Old Mar 28, 2010 | 03:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Corvettes of Houston I would also pull the circuit board out of the silver box and look at the circuit board to see if the traces are corroded. If they are, a soft nylon brush and alcohol will fix it.
Disconnect the battery before you remove the box.
What DTCs are you seeing?
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
BC
Old Mar 29, 2010 | 10:39 AM
drdwallman's Avatar
drdwallman
3rd Gear
Thank you Bill. I will check the codes and let you know if any show up. My vette mechanic cleared the codes 6 months ago when he repaired the leak and connectors. The codes if any should be somewhat current.
Thanks David
To Startup Security Problem
