01Z with smoking problems!!
Old Mar 29, 2010 | 03:29 AM
boostfed's Avatar
boostfed
Default 01Z with smoking problems!!
hey everyone,
so i have a bit of a problem with my 01Z , i got it a couple months ago so i'm a new owner and haven't had this problem before. i'm very familiar with the lsx though, i recently sold my ls1 rx7 for the z and didnt have the problem with that, but on my 01 i have a smoking problem, it only happens on acceleration , there will be a billow of white smoke coming out. its not HUGE but its there, i can see it in the rear views. i did a quick search on the issue but didnt find too much on it, does anyone have an experience on this with an 01? i currently have 61k on it , mostly stock besides an intake and corsas, checked for bubbles and things in the oil neck but nothing, no leaks, no coolant smell, i dont lose oil or anything, it just smokes when i get spirited, haha, if anyone has any suggestions please let me know, thanks!
Old Mar 29, 2010 | 05:55 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
Have you tried nicorette?
http://wiki.answers.com/Q/What_can_c...om_the_exhaust
Old Mar 29, 2010 | 06:42 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Originally Posted by boostfed
hey everyone,
I had the same problem when I first started autocrossing my 01. Run a compression check or cylinder leak-down test to check the health of the engine. If it checks out here are some of the things I did to solve the smoking issue under hard acceleration while at the track.
- I no longer added the extra quart as stated in the owners manual, I just make sure it is at the full mark prior to starting the event and check it in between sessions.
- Added an oil cooler, getting the oil temp under control (< 250 F) appears to have helped.
- Switch to an oil with lower volatility rating. I'm using MOBIL 1's 10W-30 high milage, it has a little higher viscosity than the standard 5W or 10w-30 and significantly lower volatility.
My car no longer smokes under acceleration on track days and the high oil consumption in between oil changes has disappeared.
Old Mar 29, 2010 | 11:32 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ipuig Has some great recommendation.
I would also look at the posibility of excessive oil flow thru the PCV system. Remove the air filter/air bridge assy and open the Throttle Blade by hand and look inside the intake manifold. If the floor of the intake manifold is covered in oil, under hard acceleration, it will pull it out and smoke. If you see a lot of oil, a good quality catch can will not eliminate all of it but it will help!
Still Asleep has a very good point
That was my very first thought also. Coolant comsumption. Smell the exhaust and see if you can smell any traces of coolant.
Old Mar 29, 2010 | 02:02 PM
boostfed's Avatar
boostfed
very helpful! thanks everyone! ill be sure to do a check this weekend when i have time , keep them coming if anyone has any other suggestions! it actually might be because of oil though, i remember putting in the extra quart as some had suggested so we'll see, DIC indicates that i have about 90% oil life left so i'll have to check the level and make sure, thanks everyone! need to get the problem addressed before the lt's and blower go on, hehe.
To 01Z with smoking problems!!
