which ac compressor to buy??
ACDelco 15-20729, 15-20746, 15-21218
CarQuest / NAPA 254374, 274296
Compressor Works 620746
Delphi CS0132
Denso 471-9175
Discount AC Parts: 60-00986RC, 60-00986NA, 60-00986NC
Frigette 204-1148, 204-1514
Four Seasons 67277, 68277
General Motors 1137007, 1137008, 1137026, 1137031
Proliance 2690, 2690N
Spectra Premium 0667277, 0668277
Visteon 000672, 010330, 11400
I didn't research all of those on your list, but based on what little I did, it is apparent that one or two are offshore (probably Chinese made) copies of the compressors used by GM (and other companies). There appear to be several "Me too, me too" oufits trying to get your money and I would stay away ("Discount AC Parts" was one in particular) from them.
The first thing you need to decide is, do you want to go rebuilt or new?
If you go rebuilt, there are a cazillion (scientific term
) rebuilders out there and quality can vary all over the place. The obvious big advantage to rebuilt is price. The trick is to buy from a reputable rebuilder (some of them prefer the term "remanufactured" as it is better for marketing) that can/will stand behind the product if there is a problem and from whom you can get a replacement fairly easily. Btw, rule of thumb: If the ad for an item doesn't specify rebuilt or "reman" but has a "core" charge, it's rebuilt. So, "core charge" will tell you right away it's rebuilt.If you go new, there is a better likelihood there will not be problems with the quality of a rebuilder's choice of internal parts, since you will be the first to use it. There seem to be (again, probably Chinese) manufacturers out there that are copying the OEM manufacturers' parts, but personally I would stay away.
Based on your list, I would recommend:
ACDelco - New or rebuilt
NAPA - rebuilt (good reputation on warranties and many locations)
Delphi - new (if you have a source)
Denso - new(if you have a source)
GM - new (get prices from Gene @ GM Partswarehouse or Bob @ Fichtner Chev 1-800-234-5284)
Visteon - new (if you have a source)
Four Seasons - new or rebuilt
I'm somewhat impressed by "Compressor Works' website and catalog setup. They claim to be selling new items, but I can't tell the source (offshore or domestic). If I were to guess, I'd say offshore but I may be wrong. They are located in Dallas. You can always call them or e-mail them for that info. If you do go with them for "new", I would suggest taking advantage of their "Standard AC Kit" package (part #690844) which includes accumulator (drier) and orifice tube, because ANY compressor you buy will have ZERO warranty unless you also install a new orifice tube AND accumulator/drier. I don't think CW sells direct so you may need to check with them for where you can buy their products.
Personally, considering the work and $$ involved, I prefer new.
HTH
I attribute part of that longevity to having installed ICE 32 a number of years ago. There are several other products that do the same thing, but the biggest thing it does is reduce the internal friction of the compressor, thereby increasing it's life and also increasing it's efficiency. Come time to replace my compressor, I will use it again.
