Heat rated O2 sensor???? which one?
Old Apr 1, 2010 | 02:42 PM
baezi z06's Avatar
baezi z06
Default Heat rated O2 sensor???? which one?
Hi
i´m struggling in sensor problem getting these codes p0135 and p0155 and te car drives bad on low rpms....
i think i need new "better" heat rated o2 sensors and i´m leaning to these Bosch 13111
Are they the best or are there others that rate better.... ?
thanks
Baezi
Old Apr 2, 2010 | 01:42 PM
kendo347's Avatar
kendo347
Old Apr 2, 2010 | 03:09 PM
sami85L98's Avatar
sami85L98
Drives bad because ECM not in closed loop, i check your sig, you have headers and lots other mods, make ssure 02 sensor fuses are OK under hood fuse block, hook up EFIlive or HP tuners and see if 02 sensor readings switching back n forth from .1-.8 volts, closed loop or open loop? BTW if no luck than check the voltage of 12 volts on one of last pin of connector, its a 4 wire O2 sonsor harness connector with Key ON Engine ON, thats heated circuit pin and may be not getting power from ign source and so not heating sensor and so not going into closed loop.
If you have not turned off rear O2's than its about time turn them off, and sorted out front one's at the same time.
Old Apr 6, 2010 | 08:31 AM
baezi z06's Avatar
baezi z06
my Fuses are ok, and i checked the voltage in threw the plugs from the pcm wires after i disconnected the sensors and they measured ok, and then i swapped the bank1 and 2 and was ok for few miles but then it started to come up whith same code but now on the other side p0155 , so it´s the sensor ...
I have no rear sensors ..
but the question is why is all my sensors fauling...
Baezi
Old Apr 6, 2010 | 11:24 AM
jedblanks's Avatar
jedblanks
Check for exhaust leaks near the O2 sensor and check for unmetered air entering the intake after the Mass Air Flow Sensor.
If the PCM sees extra air that hasn't come through the MAF, it will temporarily go lean, then dump in a bunch of fuel to compensate. This causes poor driveability and bad gas mileage.
Old Apr 6, 2010 | 12:04 PM
baezi z06's Avatar
baezi z06
that´s exactly what is happening now.... it act´s bad, poping and bad throttle response under 2000rpms but after that it´s fine, but i thought it was something in the tune was going to add more fuel down there.....
how is the best way of knowing that it isn´t air leak, unmetered air going threw can´t find any thing by looking, and it does idel fine so..... ??
thanks
Baezi
Old Apr 6, 2010 | 03:30 PM
lateforwork2's Avatar
lateforwork2
So, it drives rough when those CEL's are on, but how about when you reset them using the (options/fuel 4x)? I am getting 1133 and 1153 if i remember correct, front sensors have gone bad I think.
When I reset the CEL, it drives nicely. What is the PCM doing behind this? Am I hurting anything?
Old Apr 6, 2010 | 04:30 PM
baezi z06's Avatar
baezi z06
it doesn´t change if i clear it out or not..
Old Apr 6, 2010 | 11:43 PM
jedblanks's Avatar
jedblanks
I have a cam and tune and I thought the same thing for 2 years. See I had a professional install the cam, then some jackass (me) installed the Vararam, longtubes, LS6 intake, heads etc.
Last month I found a crooked donut gasket at the collector, right before the hi flo cats and right next to the o2 sensor.
I also found that a clamp had been too tight and caused one of the plastic air bridge peices to deform and let air in through the bottom where you couldn't see it.
My advice is to take off everything between the MAF and throttle body and inspect it for cracks, funky clamp joints, or other irregularities.
It ran funny all that time, and from time to time, it would throw this or that 02 code and I'd try to fix it. Sometimes 6-7 months with no codes.
It runs much better now. I'm just keeping my fingers crossed that the o2 codes don't return anytime soon.
Old Apr 7, 2010 | 12:56 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What is the HEATER VOLTAGE (ignition on engine OFF) and what is the ground wire reading (OHMS) for the heater circuit (pin C "black wire" to chassis ground ) ????
Bill C
Old Apr 7, 2010 | 11:27 AM
baezi z06's Avatar
baezi z06
Bill C
same voltage both side
high 11,98V
low 4,42V
but what should i see on black wire C to chassis ground?
Baezi
Old Apr 7, 2010 | 05:49 PM
baezi z06's Avatar
baezi z06
high 11,98V
low 4,42V
Baezi
black wire to chassis ground were
one side 15.17 k ohms and 0 ohms
other side 14.98 k ohms and 0 ohms
is that normal K ohms????
Baezi
Old Apr 7, 2010 | 06:00 PM
lucky131969's Avatar
lucky131969
Baezi
No that's not normal. It should be a direct short to ground (very low ohms). Based on that reading, you have a problem. If all sensors read the same with reference to ground, the issue is most likely at the splice pack.
Old Apr 7, 2010 | 06:19 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Mike
I think he was reading back thru the sensor. He has 4 readings.
You only need the readings from the harness connector from the PCM to ground. If that is zero, your fine.
As for the LOW heater voltage, how did you read that?You should be reading the pin D in the connector harness that comes from the PCM to ground.
The 11.98 VDC looks fine.
You can read the HEATER element of each O2 sensor on pins C to D on the sensor pigtail, They should both be close to each other
BC
Old Apr 7, 2010 | 06:21 PM
lucky131969
Mike
That would make sense, if not, he has a serious ground issue....
Old Apr 8, 2010 | 03:23 AM
baezi z06's Avatar
baezi z06
all these readings are threw the plug from the pcm hardness not the sensor.
the sensor only shows 0 ohms ???
i´m all confuse here....
Baezi
To Heat rated O2 sensor???? which one?
