Error message
Old Apr 2, 2010 | 05:01 AM
rloughlin's Avatar
rloughlin
Cruising
Default Error message
I have a question, I own a 99 coupe and have a DIC code P1416H, I see that this is Air system bank 2-B. My question is where is the sensor located so I can go look to see if it just needs cleaning or replacement.
Bob
Old Apr 2, 2010 | 07:05 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Have you tried just clearing the code to see if it comes back?
Old Apr 2, 2010 | 08:27 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Here's a good thread on the subject. I finally replaced mine, only after several cleaning attempts that only provided short term results.
Here's the link: http://forums.corvetteforum.com/c5-t...eck-valve.html
If you go to post #79 in the above thread, you will see the actual insides of the check valve that was removed from my car at only 30k miles. Bill Curlee took it apart, and posted pictures of the failed internal parts.
Since you're showing an H after the P1416, which means only a HISTORY code has been set, cleaning the check valve might buy you some time, before an actual replacement of it is needed.
Old Apr 5, 2010 | 08:06 AM
Quicksilver Vert 01
It looks like we're not going to hear any more about this one Eric.
To Error message
