identify heads
Old Apr 2, 2010 | 08:34 AM
Blow Torch's Avatar
Blow Torch
Default identify heads
How can you identify which heads are on a car (specifically if 243 heads) if the #s have been removed from the pads at the end of the heads?
As I had posted in the past, when my wife's LS1 car dyno'd unexpectedly high, we looked at the heads to see which heads it had, and all the #s had been ground off the pads (you could see the grinding marks)
Is there some #s under the valve cover to identify the heads?
Old Apr 2, 2010 | 09:10 AM
Uncle John's Avatar
Uncle John
The only thing I can think of is that you would have "D" shaped exhaust ports as opposed to round ones on the 853 and 241 heads.
Old Apr 2, 2010 | 09:27 AM
Blow Torch's Avatar
Blow Torch
hmmm; So the 243 heads have D shaped exhaust ports?
I can't believe i hadn't heard that before But then I guess I've never really seen any Z06 heads before.
Old Apr 2, 2010 | 11:12 PM
VET-005's Avatar
VET-005
There are casting numbers under the valve covers that can clearly be seen. Valve cover easier to remove than pulling off the exhaust manifold.
Old Apr 2, 2010 | 11:26 PM
Blow Torch's Avatar
Blow Torch
Thanks; That's what I was hoping for.
Is the same three digit #s as on the pads?
Old Apr 3, 2010 | 12:52 AM
KCvetteowner's Avatar
KCvetteowner
should be two sets of 4 digit numbers cast in the top of the head. My LS6 heads had 1256 4243
To identify heads
