Cold Air Intake with nnew mass flow sensor
Old Apr 5, 2010 | 05:07 PM
rmvoort's Avatar
rmvoort
Cruising
Default Cold Air Intake with nnew mass flow sensor
I recently installed an new cold air intake system with K&N cone filters along with a new mass flow sensor on my 2004 corvette. After 20 miles the check engine light came on and stayed on. I looked at all connections and things looked OK. After returning home I switched back to the stock air filter system and the light immediatley went off and hasnt come on since. I was told when I purrchased the kit there would be no addition programing or other work needed. Is this normal and is there a solution? Will using the old stock MAF with the new cone filters eliminate the problem?
Old Apr 5, 2010 | 05:38 PM
BLUE Y2K's Avatar
BLUE Y2K
I have seen those "cone" filters cause MAF sensor problems more than once, especially in cooler weather and not just on Vettes.
Old Apr 5, 2010 | 07:38 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
did you keep the same new maf installed also?
Is it possible that oil from the filter reached the replacement maf wire causing the issue and after replacing the maf to stock you no longer see the issue?
Old Apr 5, 2010 | 09:12 PM
Jnape's Avatar
Jnape
Was the new MAF Stock or Granatelli or such. Aftermarket MAF units are a real problem with your tune or to tune in general. If you exceed your MAF working range 600+++ you could do an SD tune and remove the MAF.
Old Apr 6, 2010 | 02:02 PM
rmvoort's Avatar
rmvoort
Cruising
The manufacture told me that becuase of the new MAF it may take up to 30 to 50 miles for the computer to adjust? or just go back to the stock MAF
Old Apr 6, 2010 | 02:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What were the DTCs. A MAF is a plug and play sensor. Should just bolt in and work.
Old Apr 6, 2010 | 03:21 PM
chaase's Avatar
chaase
St. Jude Donor '12
They are garbage and many members have reported problems with Granatelli MAF.
Old Apr 6, 2010 | 03:54 PM
rmvoort's Avatar
rmvoort
Cruising
What do you mean by DTCs?
Old Apr 6, 2010 | 05:23 PM
WalterSobchak's Avatar
WalterSobchak
Digital Trouble Codes. Search the forum there are several posts on how to pull the codes from your DIC(The thing that tell you the info behind your steering wheel). I'm betting it was your MAF. I have never seen a filter directly cause a code in any car. However If there is too much oil on it it can get on the sensor in the MAF and you can try cleaning it with Sensor Safe cleaner. The DTC's will tell you what the cause is!
To Cold Air Intake with nnew mass flow sensor
