Help,car won't start
Old Apr 5, 2010 | 08:26 PM
99mikeb's Avatar
99mikeb
Default Help,car won't start
It's a 99 FRC and having a problem starting it.Took the car to work today with no problems ,came home park in the driveway in front of the garage and now it won't start.
I tested the battery with a volt meter and have 12.9 to 13.00 at the battery.
I removed the negative side and waited a few minutes and reinstalled it.
Tryed to start the car and click second time click,third time car started.Put the car in the garage shut it down and tryed to start it and click.
Now I have a CLB with the fuel shutoff tune to 250mph.Grounds are all clean.
Is my problem in the key switch,battery,starter,?????
Please help
Old Apr 5, 2010 | 08:53 PM
65GGvert's Avatar
65GGvert
Check the red battery cable end that goes to the starter solenoid. It may be loose or corroded. I've seen them burned so badly that the bakelite around the post was charred and breaking apart.
Old Apr 5, 2010 | 10:48 PM
Jungwirth's Avatar
Jungwirth
it could also be the solenoid it self...
Old Apr 5, 2010 | 10:50 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree with both of the above. Cable to the solenoid or the solenoid itself.
Old Apr 6, 2010 | 06:52 AM
99mikeb's Avatar
99mikeb
Default Part #
I'm searching online for a solenoid part from vendors and having no luck finding such a part.Does anybody have a part # for this part.
Thank you.
Old Apr 6, 2010 | 09:58 AM
dgrant3830's Avatar
dgrant3830
Use a mallet and give it a whack then see if it turns over. Don't over-whack it but as stupid as it sounds, it might just work therefore verifying it. If you get it to actuate the starter, you can buy the whole starter which will have the solenoid on it or you can continue looking for the solenoid by itself.
To Help,car won't start
