Proper Tire Pressure?
Old Apr 6, 2010 | 10:44 PM
flynhi's Avatar
flynhi
Default Proper Tire Pressure?
What is the proper tire pressure for Michelin Pilot Sports on a 99 convertible?
Old Apr 6, 2010 | 10:52 PM
Slider-01's Avatar
Slider-01
I don't have a vert but my 97 coupe with Michelin Pilot Sport ZP I keep 30psi in them.
Old Apr 6, 2010 | 11:09 PM
jrose7004's Avatar
jrose7004
30 psi.
Old Apr 6, 2010 | 11:59 PM
rws.1's Avatar
rws.1
30 psi spring and fall....
With the hot roads in summer I drop to 28 cold.... but that is just me...
the door plaque says 30 psi all around
Old Apr 7, 2010 | 12:36 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% 28-30 is optimum and in the summer, 28 will get you 32-34 HOT. Best optimum pressure for best wear and daily traction.
Track,,,,drop it to 23-25.
BC
Old Apr 7, 2010 | 05:07 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Depending on ambient temperature...whatever it takes to get it to 30-31psi hot...for me that would be 27 in summer and a little more in the fall and winter...
Old Apr 7, 2010 | 09:26 AM
warlock007's Avatar
warlock007
my question is the same, i understand the door sticker but thats for stock tires that come on the car, I've always been told to go 5-10 lbs less than tire recommendation. is there a difference when you are running run flats compared to non run flats? When i use to work at town fair tire in CT. we always told people that you wanted the tire to look flat (even) across the top of the tire and that would give you even wear. of coarse that was a long time ago.
So I am in the same situation with this question. I am putting on GY gs-d3 tires that are stamped for 51 max hot so in thinking you'd want it around 38-42 which leaves allot for temp but also if the pressure is low it does effect your MPG.
Any thoughts from the experts would be greatly appreciated.
Old Apr 7, 2010 | 09:57 AM
bobby777's Avatar
bobby777
30---THIRTY----thirty----40 minus ten=30---
Old Apr 7, 2010 | 11:04 AM
byronhunter's Avatar
byronhunter
If you follow this line of thinking, you'll KILL a good set of tires and learn a new lesson.
Old Apr 7, 2010 | 12:30 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
its not just you, some of us are much smarter than others.
Old Apr 7, 2010 | 12:39 PM
Evil-Twin's Avatar
Evil-Twin
Throw away anything you learned " A LONG TIME AGO "... technology has changed dramatically... if you can wrap your hands around the notion that road temps make the tire pressure higher or lower. the tires are designed for cars that fall within the weight bearing range. 30 psi is the right pressure, but its the right pressure when you are actually using the tires, not when they are cold... a 30 psi tire, taken out in a 90 degree day on a black top road that can hit 140 F. can take your cold 30 psi temp to 38 psi... this will cause a 30 % loss of footprint and premature center tire wear... keeping the tires around 30 psi hot is the correct way to get the most traction, tire wear and Miles per gallon, yes I said miles per gallon. Tire tuning is was Nascar does, it get them another two laps and few more mpg, that why they monitor tack surface temps and adjust accordingly
The tires manufacturer makes little difference
Old Apr 7, 2010 | 09:47 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by bobby777
30hot---THIRTY hot----thirty hot----40 minus ten=30hot---
Fixed it for ya
It would be great if ET chimed in on the "30 hot thingy...actually (30-31)hot...
Old Apr 7, 2010 | 09:50 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
If you are going to put 38-42 psi in your tires I think you will even get better mpg if you put in the max of 51 psi...
Old Apr 7, 2010 | 10:02 PM
byronhunter
Yello95, I didn't post that!!!!!!!!!! It was posted in a previous Post. Go back up and read post #7, ok?
Old Apr 7, 2010 | 10:22 PM
pcbunn's Avatar
pcbunn
I don't know if it makes alot of difference but I'm running 32psi in my new PS2's. I ran 30 in my Goodyears and I can't really tell the difference with the additional 2psi for basic/normal driving (whatever that is?).
Old Apr 7, 2010 | 10:39 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
...my bad....I just fixed it...
Old Apr 7, 2010 | 11:01 PM
Evil-Twin's Avatar
Evil-Twin
2 pound can make a difference... but for most people , the advantage is not worth the effort... when I say that NASCAR does tire tuning at the track.. I was saying that to show that there is an advantage. if your tires get too hard ( because of road temps increasing psi ) it can make a difference down the road.. here is an example for you... My first set of tires went 45,000 miles, I use tire tunning.. I posted this way back in 2005, all four tires wore evenly and when I repllaced them fronts has 3/32 left and the rears had 2/32 left... I am not an agressive driver but I like to have fun espeically in the clover leafs, and launching onto the freeway... have a perfect contact patch gives you the best advantage for cornering, mileage, braking, and tire longevity.. tires at 500 dollars a pop might prompt some people to get every driving mile 0ut of them. IM just trying to tell people they can make a difference watching their tire pressure... for most of us these cars are summer cars... if your area sees 90 + temps in the summer, and you drive on Black top roads. it would be to your advantage to take a peek at your actual tire pressure one day when its 95+ and your on a black top road... if its 36/37/38 psi, you are just burning rubber.. a simple adjust ment one time can pay for your efforts in real savings.. Most here who have followed this guide line are setting their cold temps to 26/27 psi when its in the 90's, the more over 30 psi when hot the more your wasting your hard earned money.. there is no advantage to high tire pressure other than show boating... with a reduction in tire patch area the rear tire spin much more easily.. if you thing that is cool that is great, but you are erasing the center of your tires and that can get expensive, Ive seen guy destroy their tires in under 10,000 miles, and to think , I got 45,000 miles out of my first set.
The End
Bill aka ET
To Proper Tire Pressure?
Old Apr 8, 2010 | 12:10 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
The End
Bill aka ET
thats what I'm talkin bout...classic ET
Old Apr 8, 2010 | 01:23 AM
thisMSGgood4me's Avatar
thisMSGgood4me
Then why does GM tell us that it should be inflated to 30 psi COLD instead of hot? Why not just tell us that it should be 30 psi HOT, we're not morons, we would understand that, if we know how to operate the vehicle, we should be smart enough to understand what 30 psi HOT would mean. Geez, give us a little credit!
Old Apr 8, 2010 | 10:22 AM
Evil-Twin's Avatar
Evil-Twin
The sticker is known internally as the Idiot proof sticker...so many people where inflating their tires to the max pressure found on the sidewall, the sticker is there for product liability and compliance. I'm not forcing this down your throat... 30 psi will work whether you are in Bismark North Dakota at -10 F or in the Arizona desert at 115F. Give you a little credit? you have no idea what the average drivers will interpret things. They buy oil that says 15,000 mile oil, and they drive 2000 miles a year so they dont change their oil for 5 or six years and want GM to back their blown motor. We design things at GM using a process called FMEA.. Failure Modes Effect Analysis, part of this process is trying to determine exactly what the consumer will do with this design, push this outside its design limits etc.. Just look at the credit you speak of.. do a search on people putting 44 psi in their tires because is says so in the sidewall. You see one of the nice things about this forum is that we can fine tune your car for the conditions you see in your area. We on the other hand have to design and build a car that will operate safely anywhere in the world. There is nothing wrong with you questioning me.. If it gives you pleasure to post a commentary based on you opinion and mechanical expertise and feel it is logical, I am very happy for you putting me in my place.
Thank you for your thoughts
Bill aka ET
