Remove key wait 10 sec, Servc. Column Lock, WITH CLB installed
Old Apr 9, 2010 | 01:44 AM
Phatfiddler's Avatar
Phatfiddler
Default Remove key wait 10 sec, Servc. Column Lock, WITH CLB installed
Please delete.
Old Apr 9, 2010 | 06:37 AM
Cybermind's Avatar
Cybermind
Your problem may not have anything to do with the column lock. Check the pellet on your key(s). Make sure they are clean. You can try cleaning it with alcohol or electrical contact cleaner. It is very important that there be a good contact between the pellet and the ignition key slot. You may also have dirty ignition slot contacts. You can also try spraying contact cleaner on the key pellet and inserting it into the slot several times. The computer needs to read the proper resistance value on your key or all bets are off.
Old Apr 9, 2010 | 12:27 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
sounds like batt voltage
Old Apr 9, 2010 | 03:00 PM
Phatfiddler
I checked the battery with a voltmeter and it is reading 13.10 Volts.
The DIC says "Service Column Lock" and "Pull key 10 sec etc" when starting, and then the engine dies.
I have a CLB installed so the column is not locked, the car will simply not stay running, with the message "Service Column Lock" whenever I try to start it. This was good since I needed a friend to help me push it out of a bad spot and I could steer.
The messages, and the car not staying on all happened at the same time.
I tried 2 different keys and cleaned them both, so I will try and clean out the ignition?
Edit: I forgot to mention, I checked the battery voltage after I had been trying several fixes with car and the interior lights and flashers were on so it may actually be higher than what i read from the voltmeter.
Old Apr 9, 2010 | 03:55 PM
Phatfiddler
Ok, I tried cleaning the contacts again with no luck. I also tried pulling Fuse 23 in case the CLB/BCM werent communicating properly.
Also, there are no codes, History or Current related to the problem I am having. The only codes are for the HVAC and TCS, both I am already aware of.
BUT, I get BCM error codes when I remove/replace fuse 23 but thats probably because I removed it, right?
LOL what next?
Old Apr 9, 2010 | 05:18 PM
Phatfiddler
8VETTE7, first off I thank you for your helping in this thread!
The car will start and idle on the first try. The DIC will then display "remove key for 10 sec" and the engine will turn off. If i wait and try again, the car will idle for roughly 2 seconds before shutting off again, with the DIC displaying "Service Column Lock"
I pulled the #25 fuse for 10 minutes and am going to see if it fixed anything.
Old Apr 9, 2010 | 05:31 PM
Phatfiddler
Ok, pulling the fuse didn't fix anything. I disconnected the battery and will reconnect it in 30 minutes to see if maybe that changes anything...
Old Apr 9, 2010 | 06:23 PM
Phatfiddler
Originally Posted by 8VETTE7
On the remote chance that the CLB has failed and somehow is creating other problems you might consider disconnecting the CLB and plugging the male connector from the Actuator back into the connector that goes off to the BCM. This puts the wiring back to factory setup assuming the GM recall service has never been done.
I was also thinking that maybe the CLB had failed, so Ill try that first since its fairly easy to swap it back to the column lock.
Also, here's a video of whats happening when I try to start it:http://tinypic.com/m/9rpqpk/3
You can see the car starts and idles fine, and then dies once the column lock problem shows on the DIC.
Ignore the "Service Vehicle Soon" as that is because I have the fuse for ABS pulled.
Old Apr 9, 2010 | 07:00 PM
Phatfiddler
I will try what you said and will take pictures of the fuse area in the passenger and under the steering column to verify that I do not have any recall mods.
I am certain that I don't but I will double-check as I installed the CLB 2 years ago and may have missed something.
Old Apr 9, 2010 | 07:13 PM
Phatfiddler
I put the key in and got the "Pull key wait 10 sec" message again, so i pulled the key and put it back in and now have the "Service Column Lock" message again. This shows up even if I put the key in the ON position without trying to start the car.
I stopped at the gauge sweep like you said (with the service column lock message showing in the DIC, so I cleared it before doing the 30 second wait), waited 30 seconds, and tried to start, and the "Service Column Lock" message reappeared, and the car shut off like before.
In the passenger footwell look for a spliced purple wire to the left of the fuse box.
EDIT: I checked and there is NOT a spliced purple wire in the fuse area. All of the connectors and wiring look factory and there are no splices or extra extensions to be found.
I think I am going to have to wait until tomorrow morning to check under the steering column since it is starting to get dark here. I fell about 50 yards short of my parking space :-(
Old Apr 10, 2010 | 12:46 PM
TEXHAWK0's Avatar
TEXHAWK0
It appears that the BCM is not getting a proper signal from the Column Lock system, so the PCM is cutting the fuel when you try to drive it.
If your actuator will still cycle, the first thing I would do is disconnect the CLB and reconnect the actuator to determine if the CLB has failed.
I assume your lockplate has been removed so the column cannot physically lock if you cycle the actuator. Correct?
When you installed the CLB, did you check to make sure that if a Harness K relay was installed, it has been removed? It is possible to connect the CLB to the Harness K wiring instead of directly to the BCM connector under the dash.
Old Apr 10, 2010 | 02:11 PM
Phatfiddler
Ok guys, I followed install directions for a CLB and reconnected the actual column lock mechanism. I'm currently getting the "pull key wait 10 sec" still and the lock is not engaging (the lock plate is still in there).
SO, I pulled the #25 fuse and will watch a South Park re-run, and then head back out and try again to see if the codes are cleared and/or if the column is locking again.
Note: I never had a problem with the column lock before, but I installed a CLB "just in case", so it should work when I hook it back up. Update coming in 30 minutes or so.
Old Apr 10, 2010 | 02:40 PM
Phatfiddler
Ok, i put the fuse back in after 30 minutes and I am still having the same problem. The column-lock worked before I did the CLB mod, but now the column-lock is NOT working at all, so a BCM problem? I can start the car, turn off, remove key, and the column does not lock like it should.
It hasn't been used in 2 years so maybe it needs some encouragement from a hammer?
See Post 23
Also, the 4 wire colors for the harness are Blue, Purple w/ black stripe, Gray, and Gray w/ black stripe - this was wrong
Old Apr 11, 2010 | 05:38 PM
Phatfiddler
Bump, car is still down
Old Apr 11, 2010 | 11:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to make sure that the BCM and PCM are getting the correct voltages. There are TWO power supplies that need to be checked. The one that is suspect is the voltage from the ignition switch. Is called "Hot in Tun and Start" or "Hot in RUN".
Here a post that details where to find those fuses. The voltages out of the ignition switch should be the same as battery voltage>
- http://forums.corvetteforum.com/c5-t...ch-repair.html
There are two holes on the top of each fuse. check the voltage there to ground.
BC
Old Apr 12, 2010 | 11:04 AM
Spoon83's Avatar
Spoon83
You may have the factory "K Harness" installed. If so, you are plugging in the CLB Bypass into the harness instead of the actuator connector and thus having two bypasses. You need to pull off your knee bolster panel, unplug the connector which leads to your column actuator and then follow it until you see wire harness and relay box (usually zip tied and wrapped in wire loom). Unplug that from the opposite end and throw it away. Now plug in your CLB Bypass and your problem should be solved.
If you have any questions, give me a call (713-206-0967) and I can talk you through it. Hope this helps.
Jarek
Old Apr 12, 2010 | 12:08 PM
Phatfiddler
Ok guys, I checked fuses 9, 13, 19, 22, 23, 25, 29, 47 and 50 in the IPC and they all appear to be good. However, I don't have a fuse 22 installed, and the cover panel doesn't list it as having a use.
I think I may have listed the wrong wire when I was mentioning colors. To help clarify I took a picture. The plug is connected to the vehicle with a white clip.
I was using the correct plug earlier, but may have jotted down the wrong colors.
Bill Curlee - I am checking out that thread you posted and will post back!
Thanks!
To Remove key wait 10 sec, Servc. Column Lock, WITH CLB installed
Old Apr 12, 2010 | 12:37 PM
Phatfiddler
I checked the following fuses with the Ignition in the ON position:
Under Hood Fuse Center
ENG ING1 FUSE# 19
INJR 2 FUSE# 18
THROTCONT FUSE# 17
INJR 1 FUSE# 22
PCM FUSE# 16
F/PMP FUSE# 13
Instrument Panel Fuse block
BTSI BU Fuse# 21
BCM 13 Fuse# 22 - I do not have this fuse
IPC Fuse# 19
Results: I measured across the fuse, so I should read 0.00 Volts if the fuse is good. 1 of the fuses under the hood and 1 of the fuses in the IPC measured 6.3mV. The rest measure 0.00V.
Also, after several days of troubleshooting my battery is now down to 11.4 Volts. Should I charge it to make sure it is not a contributing factor?
Old Apr 12, 2010 | 01:13 PM
Phatfiddler
I checked the battery with a meter, unplugged from the system. I will check the fuses again but this time to ground to see what I get.
Old Apr 12, 2010 | 01:32 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
If the battery is that low when measured disconnected from the car electrical system there is not much that is going to work correctly. The BCM needs much higher voltage than 11.4 to function properly.
How old is the battery? It may be time to replace it??...........
I noticed your odometer reading comes up when you start the car. That's an indication of a low battery because the computer has gone into default mode.
