Replacing my cam...???
Old Apr 11, 2010 | 06:56 PM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Replacing my cam...???
I have a Comp Cam blower cam I've been running for 13,000 miles. At the time I did the cam I also put in new lifters.
Question I have is:
Do I need to swap out the lifters for new ones?
What lifters should I use if I do replace them?
Thanks,
John
Levittown, NY
Old Apr 11, 2010 | 07:08 PM
lucky131969's Avatar
lucky131969
No.
Old Apr 11, 2010 | 07:28 PM
Blow Torch's Avatar
Blow Torch
Originally Posted by lucky131969
No.
That was the case with flat tappet lifters that wore to a particular lobe. These rollers will work with any cam
Old Apr 11, 2010 | 07:39 PM
2004SpiralGrey
Thanks...you guys just saved me $200
Old Apr 11, 2010 | 07:40 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
No.
but be sure to inspect them before reuse. Check the photos in this LINK and be sure none of yours look like these.
To Replacing my cam...???
