Clutch problems?
Old Apr 12, 2010 | 05:36 PM
Nver2loud's Avatar
Nver2loud
Default Clutch problems?
Hi all,
After getting the vette out for the first time for a drive around the block this year, I remembered how hard the clutch pedal is. Is this a normal problem with an aftermarket clutch? Car is an 00 m6 coupe, new master cylinder, new slave cylinder, Centerforce dual friction clutch and centerforce flywheel. last winter I rebuilt the trans and inspected everything. The pedal is so hard that I have broken the clutch master mounting bracket twice, the first time it broke the ears off the master when it went through the firewall, the 2nd time i was lucky enough to just break the bracket. After reading on the Centerforce website, the dual friction is meant to be installed one way, and according to tech support if its not making noise, its not installed backwards. I had reinstalled it the way it was prior to removal without thinking twice. I removed it to replace the pilot, and the seal behind the pilot as oil was leaking out. The car is near stock again, is it time to just get a "stock" clutch replacement to get a stock pedal feel back again? A friend of mines father has a z06, and my friend has driven both cars and said my clutch is VERY hard to push.
Any ideas?
Old Apr 12, 2010 | 06:25 PM
lucky131969's Avatar
lucky131969
Originally Posted by Nver2loud
Hi all,
Any ideas?
Do you have a remote bleeder? If so, I would be interested in knowing how much resistance there is with the bleed open, so there is only mechanical movement.....and no fluid displacement. I've never heard (does not mean it's not common) of someone actually breaking the mount for the master, as a result of the clutch pressure.
Old Apr 12, 2010 | 07:38 PM
Nver2loud's Avatar
Nver2loud
Yes, i do have a remote bleeder. That is a very good point and I will try to give that a shot tonight!!
Old Apr 12, 2010 | 07:53 PM
Nver2loud's Avatar
Nver2loud
Ok, so opened the bleeder, and I have almost no pedal resistance, I will need to get someone else to help me re-bleed now. For this fluid only being in the system for roughly a 13 months and 5,000 miles of driving it sure is nasty!!! This is with all new components too...
Old Apr 12, 2010 | 07:57 PM
lucky131969
It least that takes some of the mechanism out of the equation.
Old Apr 12, 2010 | 08:13 PM
lucky131969
I have only driven C5's with 3 different clutches: Textralia, Spec, and Monster. While the clutch feel did vary, it in no way was difficult. The force required to depress the pedal with an aftermarket clutch can be subjective; however, breaking the mount on the master suggests that you are having to impart an unnecessary amount of force to displace the slave.......which suggests to me that something is seriously wrong.
Nver2loud's Avatar
Nver2loud
Next step in diagnosis? I guess I'm thinking it has to be just a strong clutch as far as pedal feel? Would dropping the driveline to do the drill mod to the slave be beneficial? Or would a tick master solve my problems like others say?
Old Apr 12, 2010 | 08:17 PM
lucky131969
I'd be having a serious discussion with Centerforce, and ask if they have any reports of this nature. My gut tells me it has to come apart, and everything inspected. If that much force is required, it should present itself somewhere.
Old Apr 12, 2010 | 08:36 PM
Nver2loud's Avatar
Nver2loud
There is a matched centerforce flywheel on the car too...Im guessing that I would need to change out the flywheel if i went with a different brand of clutch? What would I really be looking for if/when I take it apart? Im guessing the fingers may be possibly bound up, or maybe something to do with the weights jamming up the fingers or something?
Old Apr 12, 2010 | 08:49 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
The drill mod will not help, the opposing force to the hydraulic system pressure is the pressure plate spring assembly, I would focus tropubleshooting efforts in this area.
The Tick (Tilton) master cylinder has a larger bore area, it will increase your pedal effort.
Old Apr 12, 2010 | 11:29 PM
Nver2loud's Avatar
Nver2loud
Think I can inspect the pressure plate through the inspection plate? I guess im not sure what I would be looking for it besides the obvious bent fingers or something to that effect.
Old Apr 12, 2010 | 11:41 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
I'm not familiar with the CF clutch so I do not know what you will be able to see but it's worth a try. When I inpected the movement on my LS6 clutch after installation I was able to see the pressure plate movement fairly clearly.
Old Apr 13, 2010 | 02:27 AM
Roger Z06's Avatar
Roger Z06
Spec 3+ tell centerforce to take their **** back
Old Apr 13, 2010 | 07:19 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
This is the kind or well thought out troubleshooting commentary that makes this forum so valuable to so many.
Old Apr 13, 2010 | 07:57 AM
Nver2loud's Avatar
Nver2loud
Im pretty certain that centerforce will not take something back that is not even close to brand new. I will talk to them today to see if there is some kind of solution, or things I should be looking for.
Old Apr 13, 2010 | 09:30 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
For a clutch to have EXCESSIVE force to depress the springs, it would have to be doing one or more of the following:
- Over compressing the springs
- Defective slave cylinder (binding up)
- Defective pressure plate
When you release the clutch, does it immediately release? Is the peddle hard immediately or is there some take up that allows it to be free then hard?
Just trying to get some more infor to troubleshoot.
BC
Old Apr 13, 2010 | 10:04 AM
Nver2loud's Avatar
Nver2loud
When i release the clutch it immediatly grabs. I have tried to rev it up while in gear and the clutch pedal depressed and it does not move, so i know it is disengaging all the way. The first time i took it out this year the pedal was seriously hard as a rock, and it seemed to not build pressure right away. After the car warmed up it got much much better. I cant test the pedal right now as I have to re-bleed the system from last night having loosened the bleeder to see if it mechanically had something binding. The pedal prior had a small bit of free play then it was hard almost immediately.
Old Apr 13, 2010 | 10:17 AM
lucky131969
That's just not something I'm used to. Whether it be the clutch on a newer vehicle, or my C2, I've never experienced a "hard pedal"....except on brakes.
Old May 6, 2010 | 03:15 PM
BWATSONZ06's Avatar
BWATSONZ06
any updates on this issue?
To Clutch problems?
