Left Front Turn Signal Won't Work
Old Apr 17, 2010 | 03:56 PM
black_hardtop's Avatar
black_hardtop
Default Left Front Turn Signal Won't Work
The left front turn signal no longer works. The rear (taillights) works, however it runs at triple speed. I assumed the bulb burnt out. I just replaced the left front turn signal bulb (and did my regular spring oil change/etc). That didn't seem to fix it.
Anyone ever run into this before? Electrical problems are always painful. I checked two grounding plugs (left and right), and cleaned off all corrosion and reattached them. Still not working. The right turn signal works fine.
Any ideas?
2001 Coupe.
Old Apr 17, 2010 | 04:08 PM
lucky131969's Avatar
lucky131969
Any ideas?
2001 Coupe.
Do the DRLs work?
Old Apr 17, 2010 | 05:06 PM
black_hardtop
good call. no, the left one does not, and as expected the right one does. So what does that mean?
Old Apr 17, 2010 | 05:12 PM
lucky131969
Tells me that you are either not getting 12volts to the socket, or loss of a ground. Check for 12volts at pin A (light blue wire) with the car running i.e. DRL's on. Also check for the resistance to ground at pin G(black wire).
Old May 8, 2010 | 04:05 PM
black_hardtop
Finally a dry weekend. It looks like I have both power to the light blue wire and ground from the black. Is there a diagram somewhere of each of the other pins?
Old May 8, 2010 | 04:15 PM
lucky131969
Something doesn't wash here. If you have 12volts at the light blue wire (pin A), and a good ground at the black wire(pin G), then the DRL should work. What is the resistance to ground at pin G?
The brown wire(pin B) is for the turn signal/park lamp.
If you are sure the ground is good, then you either have a bad bulb, or a bad socket.
Old May 8, 2010 | 05:56 PM
lionelhutz's Avatar
lionelhutz
An easy way to test this is to connect the meter with the negative wire to a good known ground. Then, check the circuit with the bulb in place. Look for 12V on the wire that should have 12V (the power wire) and 0V on the wire that should have 0V (the ground wire).
The connections can sometimes have a high resistance. You get what appears to be power or a ground with an open circuit but with the load (the bulb in this case) the voltage is dropped across the circuit fault and not the bulb.
Peter
Old May 8, 2010 | 06:00 PM
black_hardtop
I am an idiot. Thanks for the help. Turns out both the turn signal and the DLR bulbs were out, and that kept either one from working. 6 hours underneath that car all for another bad bulb.
Old May 8, 2010 | 06:02 PM
lucky131969
Yikes....tough lesson...bet you'll never get bit on that again..
Old May 9, 2010 | 01:21 AM
DeeGee's Avatar
DeeGee
Glad you fixed it So many guys are caught by the dual function problem
Old May 10, 2010 | 11:35 PM
spoolin7's Avatar
spoolin7
didn't want to start a new thread. on my wife's C5, the left front turn signal keeps blowing about once every 2 weeks. most of the time, the bulb itself is broken when i go to replace it. yesterday, it was just really black inside. it doesn't appear to light any brighter than the rest of the bulbs. i haven't checked voltage yet, just wondering if anyone has heard of this happening before
Old May 11, 2010 | 12:03 AM
byronhunter's Avatar
byronhunter
Yep, we've all heard it, the heat from the bulb has melted a hole in the top of the housing, and water hitting the hot bulb causes a problem.
Old May 11, 2010 | 12:18 PM
sereneDelusions's Avatar
sereneDelusions
Totally agree with this. Both of my oem corners had holes melted in the top...water killed those bulbs quick. I replaced my corners with clear outs/leds. Much better look and no more melting plastic.
Old May 12, 2010 | 12:45 AM
LuCkYSe7eN11's Avatar
LuCkYSe7eN11
My front right turn signal sometimes works and sometimes doesnt. Usually if it doesnt work the next time I start the car it does. This has only happend 3 times and there was about a 8 month gap inbetween the first and 2nd time. Any idea what my problem might be (I suspect a ground but im not sure where it is)?
To Left Front Turn Signal Won't Work
