Fix Squeaking Steering Wheel
Old Apr 19, 2010 | 10:18 PM
pdgourno's Avatar
pdgourno
Default Fix Squeaking Steering Wheel
This worked for me by laying on my back under the steering wheel. My head is near the firewall. You will see the steering column go into the green and white rings right at the firewall (see photo). I was able to slightly turn the steering wheel with my left hand while laying under there and the squeak/vibration was obvious. I used the same silicone spray I use for weatherstripping, the CRC brand I get at WalMart. While slightly turning the steering wheel back and forth with my left hand I sprayed about three short blasts behind the white ring, see photo. No more squeak at least for day one.
I would have bet money the squeak was coming from the airbag area of the steering wheel but it is not.
David in Glendale
Old Apr 20, 2010 | 11:06 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Good info. Thanks.
It's not the most comfortable position (blood rushing to your head) LOL, but I'm sure it didn't take but a minute or two.
Old Dec 17, 2010 | 07:10 AM
clif's Avatar
clif
St. Jude Donor '09-'10
David in Glendale
Now that it has been several months, is the sqeak still gone?
Old Dec 17, 2010 | 06:17 PM
00Corvette's Avatar
00Corvette
Old Jan 8, 2011 | 06:03 PM
RUNWME's Avatar
RUNWME
David in Glendale
I would have bet money my noise was the coming from clock spring between turn signal switch and airbag also, but your trick was fixed my noise! Shot some PB blaster up there ( all I had ) but if noise comes back will use some white lithium
Thanks for the tip
Old Jan 9, 2011 | 09:20 AM
pdgourno's Avatar
pdgourno
Default Did the trick
Still no squeak as of Jan 9, 2011, give it a try.
David in AZ
Old Jan 9, 2011 | 09:34 PM
99 vett babycar's Avatar
99 vett babycar
thank you, Dave
Old May 21, 2013 | 08:42 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Thanks for posting this up..had a squeak and sure enough; I bought the CRC Lithium Grease and did this and the squeak is gone!
Old Nov 2, 2015 | 09:50 AM
Keith Canuck's Avatar
Keith Canuck
1st Gear
Default Squeak in steering wheel column
Fantastic. Thanks so much for taking the time to respond to my question. I appreciate it.
David in Glendale
Old Sep 9, 2021 | 11:30 PM
dainon's Avatar
dainon
Thanks David!
This groan has been driving me nuts for years and steadily getting louder every summer. Today I got fed up with it, found your pic, grabbed a can of Blaster white lithium and and a trim removal tool and pried the firewall away from the steering position sensor you showed and jammed the straw up in there and gave it a good 10 second squirt of grease.
It immediately quieted down. Thanks for the tip and the pic!
-Dainon
To Fix Squeaking Steering Wheel
