Maf
Old Apr 23, 2010 | 06:30 PM
2079's Avatar
2079
Default Maf
I'm presently having an H/C intalled whit all the appropriate adds'on...all!!
I'm told that minimal to no gain...by descreeninig my MAF, Only a Z06 maf would provide any gain's.
Opinons please as Id like to think that I got ALL the relative parts to do my conversion in hope to get the most out of it, from recommendations I got from this forum for the better part of the last 6 months.
Opinions please.
Old Apr 24, 2010 | 04:50 AM
dieseldave56's Avatar
dieseldave56
Default Who told you ...........
Who told you that you'd get little or no gain from removing the air flow straightener screen on your LS1 MAF sensor? Why would only an LS6 benefit from a descreened MAF? Being that the 2002-2004 LS6 has a descreened OEM MAF , logic says that the LS1 could also benefit. But the intake air flow from the air box or filter(s) ducting has to be as free flowing as possible. Recent CF thread ( my #8 post)http://forums.corvetteforum.com/c5-g...af-screen.html
The gains are minimal at 5 hp or less for the LS6 (with the 2002-2004 Z06 air box) so the LS1 with the same Z06 air box would also have gains and even more with an unrestricted aftermarket filter system.
Old Apr 24, 2010 | 08:07 AM
2079's Avatar
2079
Thanks for the post, great info now I can better understand the pros and cons of doing this. And its basically in line whit what my tuner said.
Since I have a after market air filter it would be minimal gain.
Old Apr 24, 2010 | 08:16 AM
minitech's Avatar
minitech
Now is the time to do it. You will need a tune with your H/C package so the tuner can tune for any change due to no screen.
Might consider porting the body too, if it is an older style you can remove the bolts and take it apart. Cut out the metal bars in the middle. If you can, get it on a metal lathe and bore it out to max ID; trim down the plastic on the sensor.
Old Apr 24, 2010 | 09:17 AM
kp1's Avatar
kp1
The MAF doesn't "make" horsepower if it's descreened.
The Z06 didn't need the screen because the airflow didn't need to be straightened for an accurate flow determination. Leaving the screen off the Z06 MAF saved GM a few pennies per unit.
The only way you would see a horsepower increase from a descreened MAF would be if you are at a HP level that you need to take in more air than the MAF will allow. I have a screened MAF in an LS setup putting about 500 to the wheels NA. It's breathing just fine.
If it ain't broke, don't fix it.
Old Apr 25, 2010 | 04:32 AM
dieseldave56
kp1 who are you quoting that stated "make" horsepower if decreened?
It is very clearly explained why the GMPT engineers eliminated the MAF straightener screen from the 2002-2004 LS6 . I also state why the 2001 LS6 has a screened MAF and by eliminating the no longer needed screen from the 2001 LS6 and the addition of the 2002- larger opening filter box lid , one could expect an additional 5 hp. I also quote my sources. GMPT engineers admit they overlooked this for the first M/Y LS6.
Let me quote some other facts:" Two MAFs , 2001 LS6 and 2002 LS6. GM has done this ( descreen) for 2002 ought to prompt the folks who've yet to do it to older GEN 3s to remove their screens. Removing their screen and using the 2002-2004 Z06 air filter box together gets about 5 hp at flow levels such as the LS6es" . John Juriga, Asst Chief Engineer for GEN 3 engines.
The point being is that the screen is Restricive to air flow. Just as any practice that allows increased air flow in or out of and engine will equal a hp gain. Now who am I going to believe you or GM engineers?
John goes on to say" GM did what hot rodders have been doing for years with MAFs- remove the air flow straightener or "screen". What took us so long to figure that out? The LS6 is not GM's only application of the MAFs. Any use of it with an air intake duct that curves just before the MAF (typical of most trucks) needs the straighten screen to sense accurately and GM's conventional wisdom was to leave it on Corvettes ...... With Corvettes (2002-) relatively straight passage between air filter box and the MAF, the straightener isn't needed."
Note that 2005 LS2 uses a straightener screen on the MAF. GM states that horsepower was no longer the number one issue but that driveability was priority.
Old Apr 25, 2010 | 06:27 AM
VET-005's Avatar
VET-005
I went with a maffless tune and got great gains and awsome economy. I get 31.5mpg out of my 02 6 speed and just over 400rwhp. My tuner uses efi live and can do mail order tunes and even does remote tuning. I know he does alot of tuning for people all over the world and specialises in LS engines.
Look him up: www.oztracktuning.com
To Maf
