Question about knock sensors
Old May 1, 2010 | 11:16 PM
wannagofast's Avatar
wannagofast
Default Question about knock sensors
Is it possible to have a bad knock sensor and it wont set a code?? I tested them and they are reading about 99.8 ohms and set my MM to hertz and they are working by hitting the block lightly. Then I did the ohm test again and the one on the DS was reading 257 ohms..It is a ls7 block. I have got some unreal detonation issues...
The funny thing is that I have never had any Knock retard show up when scanning.. Car was on dyno did a couple of pulls then changed plugs because it lost power in a hurry on the top of one run. the plugs that came out looked new. After we changed plugs did one pull pushed coolant out surge tank stopped everything. Went home I pulled the new plugs and #3 spark plug ground strap was melted off.. The head gasket was burnt really bad on #3 and you could #4,5,6 where all starting...I looked at my tune and cannot see that it has been desensitized... if you over/under torqued them and damaged them would they still not set a code??
Old May 27, 2010 | 07:38 AM
baezi z06's Avatar
baezi z06
Think i have same issue here...
never seen any knock retard on my new LS2 402, was running ls6
but now i suspect damadge piston....
got low compression on cyl 7 (100) and bent spark plug. there
I first saw blue oil at WOT and then it started backfireing and popping / stalling
think it´s maby been knocking
Baezi
