Windshield Washer Leak
Old May 2, 2010 | 04:23 AM
customizer's Avatar
customizer
Default Windshield Washer Leak
I have a problem with water coming out of the windshield washer hose on the wipers when I drive the car at high speed but no problem when driving slow. What can I do......Thanks!
Old May 2, 2010 | 09:53 AM
jhiiidoc's Avatar
jhiiidoc
Gotta live with it. At high speed, the wind passing over the wipers creates just enough suction to pull the fluid out of the lines. Mine used to happen at about 80.
One way around it would be to purge the lines. Which means driving with no fluid in the tank. Not something I'd do, but to each his own.
Another way (which I discovered by accident) is to buy a hood (any hood with a 1.5 inch rise or more) with a broad blister that extends above both wiper fluid outlets. This raises the wind over the wipers, eliminating the issue. I have an RK Ram Air hood which ended that problem.
Old May 2, 2010 | 11:16 AM
65GGvert's Avatar
65GGvert
Do a search. A while back, someone posted about a check valve (I believe a Ford part) that you could put in the line from the washer tank to stop the fluid at speed, but allow washer to work.
Old May 2, 2010 | 12:25 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Couldn't you just open the little hole on top of the fill cap a bit more? Wouldn't that give it less pressure in the tank to begin with so it wouldn't force it to the wipers?
Old May 2, 2010 | 10:43 PM
jhiiidoc's Avatar
jhiiidoc
Tank pressure isn't the problem. I'd summize that if you open the hole more, it would increase the likelihood of leaking by allowing more air pressure on the tank side as more negative pressure is created above the wipers.
Old May 8, 2010 | 03:18 PM
Slinkyv's Avatar
Slinkyv
I have a similar problem but mine will leak under any hard acceleration, especially in 1st and second gear. It dribbles like an excited dog. Kind of funny actually.
Old May 8, 2010 | 06:39 PM
striper's Avatar
striper
I just don't fill the tank all the way, keep it low enough to stop leaking but high enough that the low warning light doesn't come on. I can accelerate hard enough to force water out the nozzles. I avoid rain so it's not a problem. As also mentioned, there is a Ford check valve that will stop this problem for the bad weather drivers.
Old May 8, 2010 | 07:25 PM
87SAM's Avatar
87SAM
That works or me also.
From the service manual:
Document ID# 1297626
Chevrolet/Geo Corvette
Windshield Washer Nozzle Leaks on Windshield - appearance bleed check clearance damage fluid leak valve wet water window #PI00990 - (Apr 14, 2003)
Windshield Washer Nozzle Leaks On Windshield - appearance bleed check clearance damage fluid leak wet water valve window
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
Windshield washer fluid drips onto windshield when accelerating or at highway speeds.
Recommendation/Instructions:
Install check valve PN 22102237 in the washer fluid hose before the tee to both nozzles with the arrow on the valve pointing in the direction of fluid flow. Verify operation of pump.
Old Jun 27, 2010 | 07:09 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
What an extremely annoying problem! Here lately the washer fluid will not stop leaking out of the wiper nozzles even after the car is parked in the garage. My entire washer fluid reservoir emptied out today...lol. I wonder if Gene can get me one of the check valves (I also ordered a new washer fluid pump)?
To Windshield Washer Leak
