Help Service Engine soon
Old May 3, 2010 | 06:08 PM
rhladek's Avatar
rhladek
Cruising
Default Help Service Engine soon
Have a 1997 with 53,000 Miles.Get the message on my DIC reset and disappears till I start up the car next time. I have no codes both me and my mechanic checked. Help Help
Old May 3, 2010 | 06:48 PM
dougbfresh's Avatar
dougbfresh
What do you guages say at the time? Check the code(s) when the CEL comes on.
Old May 3, 2010 | 07:06 PM
rhladek's Avatar
rhladek
Cruising
it is not the check engine light,it is service engine soon where your mileage is,and again no codes
Old May 3, 2010 | 07:40 PM
lucky131969's Avatar
lucky131969
You are sure the message is "Service Engine Soon" ?
Old May 3, 2010 | 07:45 PM
dougbfresh's Avatar
dougbfresh
That's why I asked WHAT THE GUAGES SAID at the time. If something like temp gets too high, oil pressure sensor pegs out or fuel guage gets freaky you can get messages that do NOT set codes.
Old May 3, 2010 | 08:35 PM
rhladek's Avatar
rhladek
Cruising
Nothin on the gauges since it happens when i start the car up,I had it stored for the winter and when I started it the message came up again
Old May 3, 2010 | 08:47 PM
dougbfresh's Avatar
dougbfresh
Probably a weak battery, did you have it on a battery tender for the winter?
Old May 3, 2010 | 08:50 PM
rhladek's Avatar
rhladek
Cruising
Had it before car was stored and it is a new battery
Old May 3, 2010 | 09:28 PM
dougbfresh's Avatar
dougbfresh
Check voltage on the battery.
To Help Service Engine soon
