Clay Bar
Old May 4, 2010 | 05:13 PM
DARRYLZO6's Avatar
DARRYLZO6
Default Clay Bar
This has probably been addressed at one time here but I cant find the info. I would love to know the proper way to use a clay bar. My Z is black and hood looks like crap, so im looking to cure this soon. The summer sun shows quite a bit. Any advise would be appreciated. Thanks.
Old May 4, 2010 | 05:15 PM
olefam's Avatar
olefam
Easy to use and well worth the time and effort. First, buy a Clay bar kit (I used Mother's) Next, read and follow the instructions printed on the box. Finally, enjoy your accomplishment.
Glen
Old May 4, 2010 | 05:26 PM
03WhiteConv's Avatar
03WhiteConv
Check the car care section, they're nuts about the clay bar!! I just bought a Turtle Wax ICE claybar kit, havent tried it yet.
Old May 4, 2010 | 05:29 PM
Chicago1's Avatar
Chicago1
Yup car care section is where you want to go, some of those guys are about perfect paint.
Old May 4, 2010 | 09:01 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I was told all the clay bar material comes from one spot in Japan.
Old May 4, 2010 | 09:49 PM
KCvetteowner's Avatar
KCvetteowner
I haven't found a clay bar yet that is close to the Griot's Garage Clay bar....their clay is much much easier to work with, the others seem like a brick in comparison.
Old May 4, 2010 | 10:01 PM
jrose7004's Avatar
jrose7004
They have a great Car Care discussion forum here at CF.
Old May 5, 2010 | 11:07 PM
fcable's Avatar
fcable
One suggestion for your black Z...I have a black convertible, and it does have some chips in it. All the waxes I used left white dried wax in those chips, just highlighting all the imperfections. I tried Turtle wax "Black Box". It is the greatest thing since sliced bread for a black car...it make the finish look like new!
Old May 5, 2010 | 11:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Wash the car as normal. Rinse well. Make a extra rich bucket of car wash (two caps of wash vise one) and soap up one area of the car. Flatten the bar out into a pancake and just rub it on the soapy area until the paint is silky smooth. Then move to the next area. I rinse each area to prevent it from drying.
After the clay bar treatment, you can use some ICE wax.
WARNING! If you drop the bar on the ground,,,throw it away!!
BC
Old May 6, 2010 | 04:20 AM
dieseldave56's Avatar
dieseldave56
Default Meguiares............
Been using clay bar for 20 plus years since it first came out. Yes the Nippons get credit for its discovery.
First is to prep the clay bar. I flatten it and fold it over several times like a you would a terry cloth removing wax. As the clay gets contaminated with the bits of crap that was embedded in your paint it will discolor and you'll need to fip or fold it over to a clean side. Clay bar has limited life.
You'll need a lubricant. Soapy water will do , but I use the spray on detailer wax ( I buy it by the case so i have it around). This lets the clay bar slide easily across the paint surface.
Bill's correct in if you drop it on the ground , throw it away.
Just read the directions on whatever product you get. Really helps .
Old May 6, 2010 | 12:07 PM
rbrtclk's Avatar
rbrtclk
I clay barred my car and was amazed that I did not feel much "drag" on the bar. Was my car that clean, or did I do it wrong?
Old May 6, 2010 | 12:38 PM
feeder82's Avatar
feeder82
The clay bar doesnt drag if you do it right, with lots of lube
Old May 6, 2010 | 01:40 PM
socalman's Avatar
socalman
St. Jude Donor '10
Out of the sunlight, and using any spray detailer will work best. BUT! clay bar is only 1 easy step on your way to a good looking car or hood in your case. IT WILL NOT REMOVE swirls and fine scratches, which is what I'm assuming you are looking for. Clay bar is to remove fine dirt particles trapped when the car was waxed.
You have to cut the clear coat- using a buffer with Swirl/Fine Scratch remover, then Machine Polish compound (again with the buffer)- then wax.
check Youtube - search 'junkman2008' and watch his videos
Old May 7, 2010 | 07:10 AM
dieseldave56
Default All depends ........
All depends on the condition of the painted surface. I would venture to say that 'color' sanding is a step that has always brought great rewards for abused paint. Not only eliminate the surface blems but the 'orange peel' as well. All my vehicles get 'color' sanded. Granted no all can accomplish or are successful at the task or are even willing to sand on their paint but its a skill that really shows up.
Old May 7, 2010 | 12:58 PM
TrplBlk01's Avatar
TrplBlk01
I just used the clay bar and then the new Turtle Wax Black Box. Works well. It has Black pigment in it and makes the color very deep and wet looking.
Old May 7, 2010 | 01:06 PM
DARRYLZO6's Avatar
DARRYLZO6
Is that Turtle Wax Black a new product? I know you said it works well, I may try it. And if it has black pigments, im sure it covers the swirl/scratches well. Thanks. (tell me more)!!
Old May 7, 2010 | 02:28 PM
TrplBlk01's Avatar
TrplBlk01
From what I can tell it's new and only for Black cars. The pic in my sig is before using it, just to clarify and it goes on and comes off easily.
Apply stag 1, let haze, apply spray detailer and remove step 1 and detail spray.
Apply stag 2, let haze, spray detailer and remove step 2 and detail spray.
Step 3 one final coat of detail spray, stand back and
I think I paid $20 for it at the local Auto Parts Store. It works even better if applied with and orbital hand waxer/polisher
Old May 7, 2010 | 02:32 PM
TrplBlk01's Avatar
TrplBlk01
I have the Turtle Wax Ice as well. IMHO it works best as a finisher after the car has been wax/polished. I like it because I can put it on everything even in direct 100 degree sunlight and it comes off like butter. No chalking, staining, no wax in the cracks!
Old May 8, 2010 | 11:03 AM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
I've used this stuff for a year and love the results. Take your time and enjoy the results.
To Clay Bar
