DIC Won't Stop Changing
Old May 5, 2010 | 01:12 AM
sween's Avatar
sween
Default DIC Won't Stop Changing
I have a 99 C5, auto w/122,000 miles. Yesterday, the DIC started going through all kinds of messages - change oil, washer fluid low, tire pressures, all the gauage readings. It won't stop, the reset button has no impact and I can't get to the odometer. Now happens every time I drive. Any ideas? Thanks!
Old May 5, 2010 | 01:24 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would suspect that the DIC Buttons on the RIGHT side of the IPC are suspect. Remove the IPC from the dash and disconnect the right side buttons from the IPC and see if the problems STOP.
BC
Old May 6, 2010 | 10:38 AM
sween's Avatar
sween
Default How Difficult to Remove and Replace?
Thanks Bill! How difficult is it to remove? Can you refer me to a How-To on the removal and replace?
Old May 6, 2010 | 11:14 AM
rboineau's Avatar
rboineau
Make sure your battery is fully charged, and connections are clean and tight. Low battery/bad connections can make the DIC go wonky.
Old Feb 5, 2011 | 12:06 PM
aharlan001's Avatar
aharlan001
Did anyone get this problem figured out? My dic buttons are unresponsive and the display is constantly cycling through random codes. (low right rear pressure, low brake fluid...) I replaced the buttons which didn't make a difference. I also cleaned the chassis grounds, checked the fuses, no water around the bcm... any ideas? I have full power to all the leads that go to the switch except number 1 (purple) is the problem the ipc?
Old Feb 5, 2011 | 12:21 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
You really felt the need to bring back 9 threads that are almost a year old???????
Old Feb 5, 2011 | 12:33 PM
aharlan001's Avatar
aharlan001
Sorry im new to this is there a way to undo?
Old Feb 5, 2011 | 12:39 PM
hotwheels57's Avatar
hotwheels57
All old threads of more than 45 days old will get locked. You can delete your redundant questions with a click on "edit", then "delete".
Then start a new thread of your own, giving pertinent information in detail, to help solve your issue.
Old Feb 5, 2011 | 12:51 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
To DIC Won't Stop Changing
