Engine Gurus - Need help...
Old May 6, 2010 | 10:25 AM
sperkins's Avatar
sperkins
Default Engine Gurus - Need help...
Please bear with me as I try to explain in as little detail as possible as not to lose your attention.
Background:
1999 FRC stock LS1 134K miles on the clock.
Problem:
Broken pushrod on #5 intake side. Lots of oil entering the cylinder causing massive smoke.
I obvioulsy twisted the the thing a little too hard and broke the pushrod, but that's not my concern/confusion. The issue is this. As soon as the pushrod broke, the car started smoking like a 5 alarm fire out of the left side exhaust -so much so that I honestly thought the car had caught on fire.
I pulled all of the left bank spark plugs to do a compression test before pulling the head and the #5 cylinder was blowing oil out of the hole and onto the frame rail of the car. That's obvioulsy where the smoke was coming from, but it didn't crack the piston and the head gasket was 100% intact so where could the oil be coming from?
1st pic shows #5 intake pushrod. 2nd pic is #5 and #7 piston.
Old May 6, 2010 | 10:45 AM
dougbfresh's Avatar
dougbfresh
What did the valves look like on that cylinder?
Old May 6, 2010 | 11:47 AM
Mr. Jones's Avatar
Mr. Jones
the piston looks pretty clean.
check the intake and exhaust ports for a crack.
check the exhaust manifold ports for signs of the oil to help locate source
Old May 6, 2010 | 12:11 PM
sperkins's Avatar
sperkins
I'll be putting on a different set of heads, so if these are ruined it's no big deal. I just don't want to go through all the trouble to put it all back together and find that there's a problem in the cylinder. I just can't imagine how there could be.
Old May 6, 2010 | 12:57 PM
varkwso's Avatar
varkwso
I know you probably did already - did you check for a groove in the cylinder wall?
Old May 6, 2010 | 01:08 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Examine the Valve Guide seal, the area around the valve guide for cracks/damage. If that area or the seal is damaged,,you will get oil in the cylinder.
Heres a post of a guy that may need a LS1 head if your getting rid of yours:
http://www.c5forum.com/cgi-bin/ultim...ic/1/2020.html
Old May 6, 2010 | 02:23 PM
sperkins's Avatar
sperkins
Thanks guys.
Jeff - I have not rotated the engine to examine the cyl walls. Will do that tonight.
Bill - I'll check those items tonight as well. Nothing seemed out of the ordinary, but I didn't look very hard since it was after midnight.
Old May 6, 2010 | 02:46 PM
beerkat's Avatar
beerkat
Hope that it all goes well for you.
Old May 6, 2010 | 03:58 PM
Timz06's Avatar
Timz06
You probably damaged a valve seal.
Tim
Old May 6, 2010 | 04:03 PM
zeevette's Avatar
zeevette
Good thing you're changing the heads. Those have valve damage, at the least. Good news, the block should be OK, from what I can see.
Old May 6, 2010 | 05:12 PM
varkwso's Avatar
varkwso
What heads?
Old May 6, 2010 | 06:00 PM
sperkins's Avatar
sperkins
Originally Posted by varkwso
What heads?
843's from a friends 2000 FRC. He left them in my basement after a head/cam swap. Hopefully he'll go for my offer of $10 per head (after they're already on the car).
Old May 7, 2010 | 05:22 AM
varkwso's Avatar
varkwso
- It is tough to spend money on LS1 heads so they need to be almost free...
According to my engine builder the 2004 LS1 heads are the best.
Old May 7, 2010 | 05:30 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have you checked out this post?????
http://forums.corvetteforum.com/c5-t...post1573996360
Looks like you have the same shifting issues to work on.
Old May 7, 2010 | 11:16 AM
sperkins's Avatar
sperkins
Unfortunately, my shifting issues (or lack of shifting) was caused by a mechanical clutch issue/failure the day before. But if you don't run, you're guaranteed to lose and I'm not a good loser.
Old May 7, 2010 | 11:41 AM
varkwso's Avatar
varkwso
And you should not be!
To Engine Gurus - Need help...
