I am noticing that while driving normally on drives over 1/2 hour I am getting little tiny spurts of rubber shooting off the tires. I find them on the rims and on the wheel wells. The tires maximum inflation is around 50LBS. I run them at around 40LBS or the sensors come on.
40 lbs is way too much pressure. should be 30lbs.[/QUOTE]
The manufactures rating on the tires state around 50LBS. I have though tires handled the best at close to their maximum pressure. Is this not the case?
The manufactures rating on the tires state around 50LBS. I have though tires handled the best at close to their maximum pressure. Is this not the case?[/QUOTE]
Nope, that is the max pressure the tire can handle.
At 40# of pressure, you'll be wearing those tires out quickly. Look at the drivers side door sticker not the tire sidewall. No wonder they're "overheating"...
Not a chance.
Most tires perform best will under normal hot pressures.
HOLY MOSES!!!!! 40 pounds! And you wanted to go to 50 but the TPS went happy!
When I drive from CT to Bowling Green KY the change from 50 deg to 90 degree daily temps cause my tires to increase in pressure to 36-38 PSI. I can immediately tell the difference and I have to pull over and readjust to a normal 33 HOT pressure. The car rides ROUGH and has less handling ability at those pressures. Just the opposite on the way back.
I set my 02 Z rear pressures to 28 COLD and fronts at 30 COLD and have excellent tire wear and thats where they handle the best once warm.
the tire manufacturer may rate the tires at a max of 50psi, but the car manufacturer specifies the recommended psi and it's on a tag on the driver's door! 30 psi is the way to go!
I really find it odd that so many folks go by the MAX pressure printed on the sidewalls! Guess no one ever reads an owners manual or knows to look at the drivers door for the proper tire pressures!Your tires are over inflated!
Tires are rated at their maximum weight load at the maximum air pressure.
For example, the stock runflats are rated at 1729 lbs each front and 1477 lbs each rear at 44 psi. Your car only weighs 3300 lbs so you don't need 44 psi. 44 psi would support a 6714 lb car!
You want maximum tread contact (read flat on the road) for your weight car. Overinflating tires causes them to bow and contact only in the center of the tread, causing wear out of the centers. Underinflating allows tread shoulder to roll over, wearing out the edges of the tread.
The only time air pressure should be increased is for a sustained high speed run.
FYI, the TPMSs alarm at 26 and 42 psi. ET says the sweet spot for C5 tires is 30 psi HOT.
