Car Backfiring After Cam Install??
Old May 8, 2010 | 09:30 PM
JtothaP's Avatar
JtothaP
Default Car Backfiring After Cam Install??
Ive heard that a loud pop in the exhaust (misfire) ever now and then is normal with a big cam. My car pops a lot for some reason and only since the cam install. The car is running rich and has a very good tune. Just wondering if anyone else has had this ptoblem and what can i do to fix it.
Old May 8, 2010 | 10:16 PM
dankhts's Avatar
dankhts
did you get a tune AFTER the cam install?? if you put in a big cam with no new tune, well, then.....
Old May 8, 2010 | 10:17 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is probably due to the exhaust mod you did.
Jason
Old May 9, 2010 | 12:05 AM
JtothaP's Avatar
JtothaP
Yes i have a tune. It happened before the mod though. Its done it before and after. Any ideas Jason? Im clueless.
Old May 9, 2010 | 12:20 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Data Log the engine and see what LTFT are. Check the O2 Sensor information to make sure that thee switching and working correctly. Look at manifold vacuum and make sure you don't have a leak.
BC
Old May 9, 2010 | 01:52 AM
CHIWS6's Avatar
CHIWS6
i had the porcelain (sp) part of the plug damage and that was the problem. You should check the wires as well. sounds similiar to my problem.
Old May 9, 2010 | 08:55 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Mine pops and such when decelariting, wish it did it more, I love it .
Old May 9, 2010 | 03:00 PM
JtothaP's Avatar
JtothaP
Its not bad. I was just worried about something being wrong.
Old May 9, 2010 | 06:49 PM
Cajundude's Avatar
Cajundude
Stop by the shop and I'll have a listen for you.
Jason
Old May 9, 2010 | 07:13 PM
JtothaP's Avatar
JtothaP
Thanks bud. I just didnt want to bother you if it was something simple. Car runs great tho :-).
Old May 9, 2010 | 10:31 PM
vsocks1's Avatar
vsocks1
Jason
I would take him up on that offer! Sounds like something is going on..
Old May 10, 2010 | 02:17 AM
JtothaP's Avatar
JtothaP
For sure. Couldn't ask for a better group of guys than Jason and Stephen. Whoop Whoop!!
Old May 10, 2010 | 05:26 AM
mojo1's Avatar
mojo1
If its backfiring then some thing wrong but if is poping and such when you let of the gas that is normal, depending on your set up. I believe it can be tuned out to a cerian extent, I ask England if he could tune some more in, I guess I am the wierd.
Either way ENGLANDGREEN will for sure take care of you.
Old May 10, 2010 | 10:10 AM
Slow Z06's Avatar
Slow Z06
werd
Old May 10, 2010 | 12:39 PM
Dope's Avatar
Dope
Resident moron
All engines pop a lot, it's just that the (factory) exhaust muffles most/all of it. Freeing up the exhaust makes it a lot more audible. Camming it will make a huge increase in popping too. It should only be on deceleration though.
I've found that replacing my H-pipe with an X-pipe helped reduce it a lot too.
Dope
To Car Backfiring After Cam Install??
